Page 3 of 178 FirstFirst 123456781353103 ... LastLast
Results 31 to 45 of 2658
  1. #31
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Quote Originally Posted by Ocin View Post
    Someone have update magneti marelli by obd ? Does it work good for mileage corection with mjd 8f2 8f3 ....thx
    Envoy? de mon iPhone en utilisant Tapatalk
    Smok dont have km change for MM ecu neither OBD , dump tool or something else
  2. #32
    Mar 2011
    EU
    Quote Originally Posted by cokolo View Post
    Thank you mate,
    I would like to know if eprom read/write by obd work good, do you have this update ?
    Thx
  3. #33
    mecano_diag's Avatar
    Nice-FR
    Any New's about Dash Golf 7 ?
    Knowledge creates mysteries.
  4. #34
    lush29's Avatar
    Oct 2015
    Hi. All have an audi a6 edc 17. Ecu is faulty. some can tell how to connect ecu directly to uhds by can? Need to replace it with the doner ecu. I am reading the manual but i don't get it. Please help. Thanks
    Sent from my SM-G925F using Tapatalk
  5. #35
    In EEP
    [QUOTE=Ocin;2840258]Thank you mate,
    Thx
    Hi i have it read write work good .by OBD but waste your money and buy ioterminal
  6. #36
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    New option available in Multi UHDS tool Mercedes w222 on OBD with one or two can filters .
  7. The Following User Says Thank You to cokolo For This Useful Post:
    mileage1 (7th September, 2016)
  8. #37
    Today tested new DSG emulator for newest vag car.
    Emulator have to build inside gateway, and read dsg km as dash km.
  9. The Following User Says Thank You to gijsvm For This Useful Post:
    cokolo (7th September, 2016)
  10. #38
    lush29's Avatar
    Oct 2015
    Hi all. I am trying to replace an ecu edc17 and after i put all old and new cs.pin.vin i get fault data changed error 2E. Any one come across this? Thanks
  11. #39
    Sep 2015
    Car: Peugeot 308 2008y
    I tried to block sync BSI<-> dash. The sync block was accepted by the tool, but then it gives an error and the process was stopped (flash corrupted, no VIN, no mileage).
    Although the car was "dead", I was still able to communicate with BSI. Backup of flash brought the car back.
    I was told later, that the sync block functionality does not work properly. So use it at your own risk
    Without "sync block" option it worked like a charm.
  12. #40
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Yesterday Porsche Cayenne 2013 (92A) 5 minutes job and reset service interval
  13. The Following 2 Users Say Thank You to cokolo For This Useful Post:
    mileage1 (9th September, 2016), Shemek (10th September, 2016)
  14. #41
    today I had some problems with 407 jonshon control and c3 valeo. I stoped few times and I had to repeat it , finally it worked after 3-4 times.
    I downloaded new all in one soft and update flash interface , hope it doesnt give me problems any more.
  15. #42
    Quote Originally Posted by nebojsapejcic View Post
    Very very very important, especially by psa, Mercedes, fiat body, is using the right usb cable.
    Use a good quality with gold contact, and also don`t put your mobile Phone direct near your interface while you are programming !!!
  16. The Following 9 Users Say Thank You to gijsvm For This Useful Post:
    hatimtai (11th September, 2016), javyb (10th September, 2016), mileage1 (10th September, 2016), nebojsapejcic (10th September, 2016), neksus (11th September, 2016), sendreq (11th September, 2016), Shemek (10th September, 2016), SKYTON (15th November, 2017), sws2011 (19th December, 2016)
  17. #43
    Apr 2014
    has any one used smok for mileage on 2010 vivaro via obd does it work?
  18. #44
    Oct 2015
    Hello
    Smok work by OBD in SID305?
    I don't know if works by obd decause it's a tricore ECU?
  19. #45
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Quote Originally Posted by Mozart1 View Post
    Hello
    Work like charm but on last places visible only with Smok km don't change when you try with Renault Clip everything is OK
    Licence Accepted
    Init CAN OK
    km=157567
    km=157567
    km=157234
    km=157234
    km=157234
    km=157234
    km=157234
    km=229595
    Read Km OK
  20. The Following 2 Users Say Thank You to cokolo For This Useful Post:
    baubynis (6th August, 2017), Mozart1 (12th September, 2016)
