Page 4 of 172 FirstFirst 1234567891454104 ... LastLast
Results 46 to 60 of 2579
  1. #46
    Nov 2010
    In New version added:
    Date of publication 12.09.2016 -Multi ECU-X v3.1.1.6
    -Added new version W204/W212 Dashboard supported (after lift too)
    -Added Option Block Synchro DASH<>EZS W211/W203/W164/W209 OBD (don't need make EZS)
    -Added Option Suzuki Grand Vitara 2011 DashBoard OBD (Read Km,Write Km,Read EEprom,Write EEprom)
    -Added Option Mercedes W205 DashBoard OBD (Read Km, Write KM )-need instal CAN Filter
    -Added Option Mercedes W222 DashBoard OBD (Read Km, Write KM )-need instal CAN Filter
    -Added Option Mazda 3/6 2015 AirBag (read/write EEp, Read Flash ,Clear Crash)
    -Added Option Oplel All Read/Change Km EDC17 Astra J , Insignia DumpTool
    -Added PSA new versions Jonson Control Write Km Fast
  2. The Following User Says Thank You to Repinator For This Useful Post:
    solitaire (16th September, 2016)
  3. #47
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    Nailed today a C4 2013-2014 with dash+bsi ~~~~ed by DP4.
    957xxx odo in dash and bsi.
    Dash+bsi made via obd2 in less that 30 seconds.
  4. The Following 2 Users Say Thank You to lupu_sandu For This Useful Post:
    PremierD (12th September, 2016), teerak2uk (12th September, 2016)
  5. #48
    Oct 2015
    Sorry but I don't understand?
    If I read with Renault clip I see the old or the new?
  6. #49
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Only new km Renault Clip can see but Smok can read old km on last places(8 position) like in new Volvo in PPD/DDM with Volvo diagnosis can see only one km (new km which you programming ) but with Smok you can see two km old and new, CEM module same thing . Other tool have similar tricks like Avdi , he can reading last 3 km in EZS but only one visible with MB Star, MB Compact , Delphi, Launch .....
  7. #50
    Oct 2015
    Ok
    cokolo
  8. #51
    Oct 2015
    Default Mercedes W176
    Hello
    I saw today that smok have soft to read and write dash in mercedes W176
    have someone try it? Where is the filter?
  9. #52
    lupu_sandu's Avatar
    In my immobox...
    You must install filter before.
  10. #53
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Quote Originally Posted by Mozart1 View Post
    Hello
    One filter in dashboard if you have new km only in dash if you want to see new km also in EZS you must put one more can filter in EZS or on OBD . In these option also have clear assyst and reset service .
  11. The Following User Says Thank You to cokolo For This Useful Post:
    Mozart1 (13th September, 2016)
  12. #54
    On the Mercedes w176, 246 etc can the assyst be set properly or only reset
    Sent from my SM-G935F using Tapatalk
  13. #55
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Quote Originally Posted by javyb View Post
    Only reset (erase all services)
  14. The Following User Says Thank You to cokolo For This Useful Post:
    javyb (13th September, 2016)
  15. #56
    Oct 2015
    Hello
    Anyone know if smok have any soft to program the V40 2013 CEM buy dump?
    I had one that was in to Oficial dealer to change the language and the old jump back?
    I think if this cars go to dealer and they make software update all jump back I don't know?
  16. #57
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Date of publication 15.09.2016 -Multi ECU-X v3.1.1.9
    -Added Option Land Rover Freelander,Discover ,Range,Evoque All terrain module OBD (finally here)
    -Read EEprom
    -Write EEprom
    -Read Km
    -Write KM
  17. #58
    lush29's Avatar
    Oct 2015
    Did some one do cas4 with smok. Is safe?
    Sent from my SM-G925F using Tapatalk
  18. #59
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Quote Originally Posted by lush29 View Post
    Cass 4 1L15Y working perfect but for mask 5M48H I would not recommend these option in Smok and 1N35H don't support .
  19. The Following User Says Thank You to cokolo For This Useful Post:
    lush29 (17th September, 2016)
  20. #60
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by cokolo View Post
    Thank you.
