Page 6 of 175 FirstFirst 12345678910111656106 ... LastLast
Results 76 to 90 of 2611
  1. #76
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by amigokola View Post
    What about reading ImmoData from EDC17, PCR by OBD with SMOK ??
    Never try pcr. But edc17 not possible thru obd.
    Sent from my SM-G925F using Tapatalk
  2. The Following User Says Thank You to lush29 For This Useful Post:
    amigokola (30th September, 2016)
  3. #77
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    PCR must be unlocked before try to read CS.
    EDC17 must be read via CAN connection.
  4. The Following 2 Users Say Thank You to lupu_sandu For This Useful Post:
    amigokola (30th September, 2016), DashProg (29th September, 2016)
  5. #78
    lush29's Avatar
    Oct 2015
    Via can conection works 100% i try it edc17
  6. The Following 2 Users Say Thank You to lush29 For This Useful Post:
  7. #79
    New All-In-One Update - Version 3.1.2.8 - no changelog to 3.1.2.5
  8. #80
    Jan 2016
    I understand that I have to wire directly X-CAN to EDC17 30,31,15,Can-H, Can-L and read it ??
    Quote Originally Posted by lupu_sandu View Post
  9. #81
    Faraday's Avatar
    May 2012
    The dark side of the moon
    yes, have to connect direct do ecu
  10. The Following User Says Thank You to Faraday For This Useful Post:
    amigokola (22nd February, 2017)
  11. #82
    Jan 2016
    Ok read's good but someone wrote here that it doesn't change data good ??
  12. #83
    Jan 2016
    You tried to adapt by direct CAN connection ?? I mean read old (immo data) and write to new on bench.
    Quote Originally Posted by lush29 View Post
    Today i try/ test edc17cp14 with smok. Read all immo data from ori and doner on the bench then try to adapt thru obd the way how is manual says, but this is the 3 rd edc17 which fails to do it.
  13. #84
    lush29's Avatar
    Oct 2015
    I read both ecus by can then try to adapt doner thru obd as per manual says. But always give me error wrong pin. I try few many many times. Contact mirek but no answer
  14. #85
    Jan 2016
    But adaptation thru can connection works ??
  15. #86
    Faraday's Avatar
    May 2012
    I did med17 and edc17 no problem read immo data ok change immo data ok.
  16. #87
    lush29's Avatar
    Oct 2015
    Unless if i do something wrong which i don't think because my friend try few times also. Any way next time i will post pictures if does not work.
  17. #88
    iamfooser's Avatar
    Sep 2012
    Something is very wrong with smok Mercedes cgw blocker for 204 and 212. I did one 212 and cgw is in bootloader so I thought it happened because I did not boost battery.
    Then came another 204, I make sure I boost with stabilizer and then it freaking happen also. So now I have 2 cars to fix. Sigh.
    Sent from my EVA-L19 using Tapatalk
  18. The Following User Says Thank You to iamfooser For This Useful Post:
    Galee (3rd October, 2016)
  19. #89
    Nov 2010
    I want to say that I did 204 and 212 successfully (three pieces)
  20. #90
    iamfooser's Avatar
    Sep 2012
    I didn't have any problem until recently. I did quite a lot before this.
