Hello
Can smok sw. 24c64 06/12 by OBD2 make Seat IBIZA 2014/2015 VDO sw. 705/805/905???
I need to know ,very important
Hello
ATRON (18th October, 2016)
And other programmer?
Do you Know?
Thank you javyb
Is there other programmer can do that??
hello all ..
Did any one try Ford fusion 2015 ??
regards
J A M I C K A
Today successfully install donor Simos PCR 2.1 in VW Passat 2012 year , original ecu is water damage and didn't get any info from original ecu . Copying/ writing CS,PIN, VIN (comfort module car )and reflash ecu from Smok database and all ok from 30 min :-)
ps. Ecu must open only for unlocking ecu with boot mode everything else goes on OBD (also km change in ecu)
THANKS SUPPORT I finished these job (first time doing this kind of work)![]()
Cokolo: what tool can read cs/pin/vin from gateway ?
Skickat fr?n min iPhone med Tapatalk
soxten (22nd October, 2016)
hello all ...
any one can tell us about this option if tried it and ok or not ?
W205 (C-klasa) Block Read orginal Km from EZS by Diag (read from EZS is same as from DashBoard)
regards
J A M I C K A
