sjc1 (5th May, 2020)
any guys experience with obd filter for mercedes to block ezs reading?
i found how to set the filter, but dont know how to connect the filter to obd plug..
thnx
Info ............ you have activated module " EU0035 Toyota/Lexus Airbag Modules on R5F617xx Read Flash by CAN (module conector) " ?
since this form only reads! but can the file be saved? I read that to clear I must also cover the form " JG0013" !
I don't see button write!
I do the clear! but then to write?!
I asked them, never an answer !!!
ThK
..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
Is there someone who did Astra K successfull with smok?
I always get message (2017 not supported)
Wbr Adam.
2017 is different than 2016.
but by eeprom is fast and easy
NO Selling Please !!
renault symbol 2017 .... 2018....2019 and dacia abs bosch not support with databess
note abs without esp ...... not suport work manulment with eeprom 95640
DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etcDo not forget to press the button thanks and reputation
# Algerian #
Is there a new smok prog available or a repair? hae used this for 8 years and in last year became un reliable.
Has any one had success reading me7.6.2 on bench i cant get any comms via can k line etc
I have a dash to modify for c3 2018 with mcu rl78. is what smok uhds + activation pt0016
only can modify this dash. for the bsi I can put it in 0km
guys need to change vin on renault megane IV from 2019 Foto..jpg wil it works with this option ? anyone tryed before ?
Hi, I have tested this option on new kangoo and works but not on all modules.
I have finish the job with Renault ecu tool and launch.
The thanks button does not burn, you can press it without any risk !
KADE007 (10th July, 2020)
Does anybody tested read D flash RH850 R7F7010183 with Smok jtag ?
And what do they mean with :
- when reading Data Flash, cells that are not programmed return random values)
Flash
