Page 109 of 171 FirstFirst ... 95999104105106107108109110111112113114119159 ... LastLast
Results 1,621 to 1,635 of 2560
  1. #1621
    Nov 2009
    europe
    Did smok can do scenic 3 dash or only abs?
  2. #1622
    Mar 2011
    EU
    Quote Originally Posted by VDO View Post
    smok do only abs
  3. The Following User Says Thank You to Ocin For This Useful Post:
    brend (27th August, 2019)
  4. #1623
    May 2018
    Has anyone tested this module?
    http://smok.com.pl/index.php?id_prod...duct&id_lang=1
    Is there a change in mileage in the Marelli MJ9DF ECU?
  5. #1624
    didi_du_93000's Avatar
    Dec 2009
    France Paris
    send file i will check
  6. #1625
    May 2018
    Hello,
    Do you need eeprom form Ducato MJ9DF for check this module?
  7. #1626
    May 2018
    Quote Originally Posted by didi_du_93000 View Post
    Dump eeprom from Ducato MJ9DF
  8. #1627
    Dec 2009
    France Paris
    check result
  9. #1628
    May 2018
    check result
    Works fine?
    I wonder if he corrects checksums when changing kilometers? What do you think? Could you check it out?
    Wysłane z mojego SM-G973F przy użyciu Tapatalka
  10. #1629
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    hy , need dump for skoda octavia dash 1z0 920 812d with 226 000 km ,i read and write with carprog but when i put dash on car apeears 250.000 ,
    please help because i check with lincnik 48 tel me i have 226... i dont now were i mistake .
    thank all
    Dec 2009
    France Paris
    Quote Originally Posted by dudus8 View Post
    Works fine?
    I don't thinks will calc the checksum
  12. #1631
    Jun 2016
    smok is supported that version
    SW: 2511
    HW: EV_DashBoardVDDMQBAB
  13. #1632
    RIMKACHIP's Avatar
    Feb 2012
    Hi all new license PT0017 learn VIN radio. Not working test with 5 cars. I wait update because nothing work. Anyone bought this license ? New license of 24 may.
    Envoyé de mon iPhone en utilisant Tapatalk
  14. The Following User Says Thank You to RIMKACHIP For This Useful Post:
    didi_du_93000 (30th May, 2019)
  15. #1633
    Feb 2010
    In EEP
    Quote Originally Posted by RIMKACHIP View Post
    Why bay licence for VIN radio? Diagbox can do it whitout problem.
  16. The Following User Says Thank You to vasa For This Useful Post:
    teerak2uk (30th May, 2019)
  17. #1634
    RIMKACHIP's Avatar
    Feb 2012
    If you can change vin on smeg+ with diagbox call me !! Only online
  18. #1635
    Dec 2009
    France Paris
    You have tested on what car?
    308 II ?
    With Tapatalk
