Page 115 of 171 FirstFirst ... 1565105110111112113114115116117118119120125165 ... LastLast
Results 1,711 to 1,725 of 2560
  1. #1711
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Quote Originally Posted by blackpirate View Post
    a friend just done one!
    easy job , just be carefull and read on manual (support list) and yeah, uncheck Advanced select flash for write , so dash reflash is to be made automatically!
    cheers
    I also tested a golf 7 2013 all ok , touran 2017 smok UHDS say its JC but it isn't, i did not tried it.
  2. The Following User Says Thank You to drpeter For This Useful Post:
    brend (19th September, 2019)
  3. #1712
    Nov 2010
    Hi, does Ford S-Max 2016 work ( KM) by OBD?
  4. #1713
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Repinator View Post
    Should do. .
  5. #1714
    Sep 2009
    Anyone tried smok on Volvo Siemens sid803A read write? Does it work obd or do you need to do by pinout
    Sent from my SM-N960F using Tapatalk
    Don't forget to hit thanks button
  6. #1715
    Jan 2010
    Quote Originally Posted by javyb View Post
    Open uhds program, click on "Help" and software shows you picture how to connect uhds on bench to ecu.
  7. #1716
    Sep 2009
    Quote Originally Posted by gijsvm View Post
    Yes I know but was wondering if a obd read is possible in the car
  8. #1717
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Not possible , I try last year .
  9. The Following User Says Thank You to cokolo For This Useful Post:
    javyb (11th September, 2019)
  10. #1718
    Mar 2016
    golf GTD 2016 VDO not ok
  11. #1719
    brend's Avatar
    Oct 2015
    Same where
    Which away not done?
    Quote Originally Posted by nourauto View Post
    NB!!! Don't ask in PM old file password , Im not remember.
  12. #1720
    esse's Avatar
    Jan 2010
    france
    tried ford fiesta 2019
    Read ok write ok but XXXXXX after few time
    sometime kms ok sometime XXXXX
    restore back up and ok
    how doing with this dash?
  13. #1721
    Jan 2010
    Quote Originally Posted by esse View Post
    Probably because you write it with the wrong software license. You need FD0021 for it.
  14. The Following User Says Thank You to gijsvm For This Useful Post:
    esse (20th September, 2019)
  15. #1722
    esse's Avatar
    Jan 2010
    france
    hi,
    yes i tried with FD0021
  16. #1723
    Sep 2013
    ES
    [QUOTE = gijsvm; 3667910] Abra el programa uhds, haga clic en "Ayuda" y el software le mostrará una imagen de cómo conectar uhds en el banco al ecu. [/ QUOTE]
    PEUGEOT 407 BSI JC full obd, ecu full sid 803 obd eeprom mpc y flash obd
  17. #1724
    brend's Avatar
    Oct 2015
    Same where
    Renault Scenic (4) 2017.
    Dash.
    Read km ok.
    Read eep/flash ok. (flash read 25 min)
    Write new km ok.
    Abs (ATE)
    Read eep ok.
    Read km ok.
    Write new km ok.
  18. The Following User Says Thank You to brend For This Useful Post:
    Mamador (3rd October, 2019)
  19. #1725
    Top Poster KADE007's Avatar
    Jun 2019
    FRANCE
    Hi to all
    someone have any experience with mode learn key on FORD CMAX year 2012 KEYLESS ?
    Thanks.
