Page 106 of 171 FirstFirst ... 65696101102103104105106107108109110111116156 ... LastLast
Results 1,576 to 1,590 of 2560
  1. #1576
    yugo45's Avatar
    Apr 2010
    Quote Originally Posted by yugo45 View Post
    Anyone can give me feed back on Mercedes W463 (G Class) 2014-2015 models .
    I need go up with km , so Can filter will not need , Just need to know how good is By OBD?
    Anyone done this car???
  2. #1577
    May 2017
    hello do you know how to make proxy alignment with the smok uhds becouse i have usue with the fiat Bravo 1,3jtd some one try to make km and no is blink is is posible to make it it the smok thanks alot
  3. #1578
    didi_du_93000's Avatar
    Dec 2009
    France Paris
    Quote Originally Posted by Mak88 View Post
    You can use any cable with free version of multiecuscan.
    Full working.
    Envoyé de mon LYA-L29 en utilisant Tapatalk
  4. #1579
    Jan 2016
    I am customer Smok ,but i need good tool or calculator to make Ecu mileage stored,that work fine and cover a lot of models of cars.EDC17 ,SID,etc ...Send me message private.
  5. #1580
    Mar 2011
    EU
    Quote Originally Posted by ATRON View Post
    NEO8 , you can use also smok dump calculator
  6. #1581
    Mar 2010
    Hello,
    I need help!
    I try to flash an V70 Dasboard (2010) with smok. ( I made full dump before) , and after is is DEAD.
    The Dash not turn on, just 2 light blinks.
    And the smok unable to flash, always : INIT ERROR... show up.
    Is it possible to reapir somehow?
    Than You !
  7. #1582
    peko's Avatar
    Jan 2010
    hi friends
    anybody know way about this on polo 2012/07
    i not undestand why not work, anybody know how use sw ?
  8. #1583
    honingkoning's Avatar
    Jun 2010
    Dessert
    Quote Originally Posted by peko View Post
    hi friends
    Try with JC option sw indication ost of the time incorrect
  9. #1584
    ghostrider72's Avatar
    Jul 2012
    UK
    Im not using that option much but I think you should read S-key first. Than change whatever you want
  10. #1585
    May 2016
    Quote Originally Posted by SKYTON View Post
    what licence for renault kangoo with this cluster
    no one know this dash ?
  11. #1586
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    What year. . is probably RT0002
  12. #1587
    Sep 2015
    hi friends
    Dash is VDO (in HW you can see VDD), read S-key first to get access, then change km.
  13. #1588
    peko's Avatar
    Jan 2010
    hi friends
    anybody have pinout dash master 2018
    is rent car and obd socket is cut of so .....
  14. #1589
    May 2018
    Hello,
    I have a question:
    is it possible to set the mileage on the dashboard in Passat B7 2014? If yes, which module?
    Wysłane z mojego SM-G973F przy użyciu Tapatalka
  15. #1590
    Feb 2015
    Lincolnshire
    Ayone tried the latest 2018 ford transit R7F (rh850) license? Any success?
    Stop getting worried about what could go wrong, and start getting excited about would could go right!
    hmmmmmmm........eeprom
    Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
