With or without cruise control ?
Your file DPF OFF. Test and r....
Salute
baltazar3 (5th August, 2016)
'" live and learn........ if you wont ....you ain't "
_______ . ____ . __ . __ . _______ . __ __ __ ... ---
If my post was HELPFUL please push THANKS button
on this ecu you must disconnect the sensor dif and the two tempsensors
before you write a dpf file you must reset the dpf to zero
emulated dpf off will work
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
I removed Dpf in few Honda CRV without emulator. All was ok.
