can not boot Imac
    Oct 2014
    Downloads
    7
    Uploads
    Default can not boot Imac
    Please help I was trying to had windows to my mac and now on startup it just keeps trying to boot up from disk and when I hold down option only the windows disc come up and no partitions. Can anyone advise how i can get the osx software to show up as my system will currently not boot up at all.
    Aug 2013
    uk
    182
    Downloads
    25
    Uploads
    Quote Originally Posted by dickypemb2344 View Post
    try here may help if you used bootcamp..osx after windows install.txt
    If i helped.... please dont forget to press the THANKS + REP buttons .
    Oct 2014
    Downloads
    7
    Uploads
    It will not allow me to go into recovery mode it just keeps attempting to boot up from disk.
    Then says disk error press any key to continue.
    Aug 2013
    uk
    182
    Downloads
    25
    Uploads
    read the whole tread because i belive you can boot from bootable usb....see..
    Alternatively you may start from a bootable installer thumb drive (Mavericks or Yosemite) or a thumb drive containing a full system (Mavericks or Yosemite).
    just a thought
    it may or maynot help you but worth a look....
    Dec 2016
    Downloads
    Uploads
    Hi there, are you still having this issue? Sounds like you killed your Mac's partition. You're going to need to repartition & reinstall.If you can't use Command R, use another Mac to build a bootable USB stick.
    Good luck.
    Oct 2019
    England, London UK
    9
    Downloads
    14
    Uploads
    My money is on the hardrive. Sounds like it has failed. Could be wrong.
