Results 1 to 5 of 5
    Nov 2011
    Default Toyota Corolla Verso - 2005 / How to program key ?
    TOYOTA COROLLA VERSO 2005 , lost ALL keys
    A new Key from dealer need to be programmed. 89070-0F022
    How and what tool can teach-in this key to the car ? I have Tango programmer.
    Aug 2014
    Get Toyota Smart Dongle, it will be your cheapest working solution if you only have a Tango.
    See Tango don't have Verso but can post a pic of module and can see if there is under any other.
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by CARPARTS View Post
    it is verry easy if you have abritus or skp900.reset immo and programming key.10-15min job
    good luck
  4. The Following User Says Thank You to rola1971 For This Useful Post:
    Sasika (8th October, 2017)
    Brayn's Avatar
    Oct 2015
    Colombo
    x100 , fvdi , ck100 , skp900, using any key programmer reset immobilizer system and program key. after you can program remote function using techstream or manual
  6. The Following User Says Thank You to Brayn For This Useful Post:
    Kalectro (27th July, 2018)
    Nov 2014
    On Tango use Smart Systems on Toyota and load dump on there it should work
