Results 1 to 4 of 4
    Canker_Canison's Avatar
    12th Level of Hell
    Default Kodi menu setup walkthrough
    I made this idiots guide to setting up the Kodi menus for part of my family. A very small part of my generally retarded family. I'm now getting requests from ebay users, but ebay don't allow links on reviews... so I'm putting it here.
    It doesn't cover how to install addons. Just the menu setup from start to finish.
    Hope it's useful...
    https://drive.google.com/open?id=0B0...Fd6ZEN6ZWFiZlE
    Kodi Menu Setup.pdf
    This link is broken and there were issues when trying to update it. Uploaded the file as a PDF a little lower down
    Not sure if the images are working... which makes this almost useless.. I'll have another look at it.
    Yet another link to try.... https://docs.google.com/document/d/0B02HCMyrEjk0TFd6ZEN6ZWFiZlE/edit?usp=drivesdk&ouid=104308657680534648967&resou rcekey=0-moTym7qvIo_-tH3SydvvAA&rtpof=true&sd=true
    Last edited by Canker_Canison; 13th February, 2022 at 09:35 PM. Reason: Another link
  2. The Following 5 Users Say Thank You to Canker_Canison For This Useful Post:
    caveman_nige (6th September, 2016), DOUGALMCD (12th August, 2016), gmb45 (9th August, 2016), oldero (10th May, 2019), smokey08 (19th December, 2016)
  3. #2
    Administrator
    Devilfish's Avatar
    Feb 2008
    Thanks Canker - Stickied!!!
    12th Level of Hell
    After much swearing... Uploaded walk through as a PDF.
    Canker
    "Animal, vegetable or mineral... I'll do anything, to anything, with anything"
    - The Baby Eating Bishop of Bath & Wells
    [COLOR=Green]
    12th Level of Hell
    Ok, I've been AWOL for a while. But I've started getting access requests for the now out of date walk through.
    If you use the default skin (Estuary). All you need to do is go to Settings > Interface > Configure Skin > Main Menu Items
    From there just deactivate everything you don't need. For most users, that will leave you with only the Addons. If you're using a NAS for Films, Tv, Music, etc ... Leave those sections activated.
    Setting up NAS access in Kodi is a pain in the ass. You will need to check the model of your NAS with the manufacturer for instructions on setting up access. Then google 'setting up NAS on kodi'. Basically, you will need to find the IP address for the NAS and the location of where you stored your media. Once you've done that, it's reasonably easy... ish.
    Google is your friend
    The other possibility is that people are fishing of an account to try and hack.
    Canker
    [COLOR=Green]
  6. The Following User Says Thank You to Canker_Canison For This Useful Post:
    Johnner (25th January, 2025)
