Page 35 of 85 FirstFirst ... 25303132333435363738394045 ... LastLast
Results 511 to 525 of 1264
Thread: X-Prog M
  1. #511
    After update to v5,0 Mircronas work OK.
    Tested on passat 2007 dash
  2. #512
    Works on all micronas, when is showing garbage, then use another car with same mask mates.
    COAX CABLE MUST BE MAX 12CM and all cable connections must be 100% OK, then you never get Error message.
  3. #513
    melbourne, australia
    I just got my xprog clone too & couldnt get it to work, ended up being the usb cable that was supplied with the unit, every time I plugged it into my laptp all of my usb ports actually shut down & wont come back unitl I restart, maybe a short inside the cable.
    but used a spare & all updated & authorisations are working
  4. #514
    Aniskey
    Guest
    Default Xprog M v4.5 Update to V5.0
    Hi can i have soft v5.0 for xprog m clone to update mine
    is v4.5
    thnx
  5. #515
    do some searching & you can see there are quite a few guys that have updated theirs to v.5 successfully. even some youtube vids that will show you how.
    I just pressed the update button on mine and viola!
  6. #516
    DK Veteran snecii's Avatar
    Hello!
    Please help me to read out dump from Megane UCH in my there is 4L91N chip
    How to do it with Xprog?
    I can not find any like that in xprog!
    I got a help with upa usb, but I think itis not the same as Xprog:
    http://www.digital-kaos.co.uk/forums...megane-161555/
    Somebody? Really thanks for help!
  7. #517
    T72's Avatar
    Sep 2010
    Quote Originally Posted by snecii View Post
    Hello!
    it is the same for xprg to, must use 9s12 adapter,
    +5v
    GND
    RESET
    BKGD
    regards
  8. #518
    Member paffendorfbg's Avatar
    Default X prog m
    Quote Originally Posted by obdmaster View Post
    ive just ordered clone xprog-m, its the same as the cheaper one from autosky, but far better price:
    China ECU Tools Centre
    Im a beginner, but the price was just toooooo good. Will let you know how i get on!!!!!!!!!!!!!!!!
    hi mate
    are you happy with it ?
  9. #519
    kautuvera's Avatar
    Exclamation help read mcu 0L72A
    hi
    I need help with Xprog and FREECALE 68hc908az60
    0L72A
    can you help me the X-PROG how to win or do I connect my wires ?
    regard
  10. #520
    puiu's Avatar
    Timisoara
    Quote Originally Posted by kautuvera View Post
    hi
    0L72A
    regard
    This MCU is secured ,to read in circuit you need this:
    $F3-$B1-$F3-$AB-$F3-$A5-$F3-$9F
    ( but can be another SS...)
    and look in X-prog manual page 17
    i think you have to read like MC68HC08AZ32
    i allways use ETL, is the best for secured 908
    regards
    Puiu
  11. #521
    hex for atmega64 xprog-m v5.0 all authorizations, fusebit config.
    exchange or sale
  12. #522
    puiu's Avatar
    Timisoara
    Quote Originally Posted by pawlenko View Post
    exchange or sale
    Here is a sharing or give for free Forum !
    NO EXCHANGE OR SALE
    regards
    Puiu
  13. #523
    kautuvera's Avatar
    Default X prog read W203 ESL
    hi,
    I read the IC have been difficult for friends who can help me?
    MC68HC05E6 mask(0F28B)
    Regard's
  14. #524
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    i think you need to use adaptor with this
  15. #525
    puiu's Avatar
    Timisoara
    hi,
    Regard's
    just lift all pin you need to connect,
    less GND and VDD ,
    regards
    Puiu
