Look in attachment,
regards
Puiu
Please see the pictures, it is not true?
I have 1 question, i bay xprog from "sinosells" in the back side off the xprog have "xprog 4.5 full" but i bay a full version 5.
May question is how have the version 5 that confirm my infos on the pichture.
einet
if you lift all the pins from PCB,
the only problem can be that you forgot to change
in programmer Option - Environment - Device
the value of Oscilator , X-Prog put this value for 2MHz osc
by default for this MCU
and you have there 4MHz so change this value to 4000000
and try again
regards
Puiu
I think you must buy upa usb. I have also xprogm but not use much for hc05. It is a good tool but has its limits. I think that for esl and key with hc05 the tool for the job is upa usb. It is a must have on every automotive technician toolkit.
I have no other tips sorry,
maybe your clone is not so god
i read with my X-prog original
exactly the same MCU from an ESL,
10 min ago just to test
if is working,and is reading perfectly,
maybe is better to buy UPA-USB original
as my god friend Sorin (tehnosoftex) recomended,
regards
Puiu
My (PB0) pin basic IC circuit to connect and I could read about it, Thank You Friends
hi
i have xprog v.5.0
i can read, but cant erase 35080
i use adapter but no succses
any advice???
if its v6 or vp then you cannot erase it mate
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
