Page 46 of 85 FirstFirst ... 36414243444546474849505156 ... LastLast
Results 676 to 690 of 1264
Thread: X-Prog M
  1. #676
    i bought a new one and everything works fine again
  2. #677
    Paraguay
    Hello, someone please MPC56 will know how to read a command placed in a Bosch M9.7 engine of mercedes?
    Thanks !
  3. #678
    Top Poster mashupishu's Avatar
    Default XPROG-m Just received ...
    Hi friends,
    I had just received (two days ago) the XPROG-m v5 that I ordered last week from ecutool, and here are my first impressions:
    First of all it is the blue pcb one, this pcb seems to be more probelmatic than the green one (the lm317 and capacitors ...) but who can choose.
    Second, a few bended pins on some connectors/adaptors (see attached images), nothing that can be repaired (someone played football with it?).
    Third, this unit have the tantalum capacitors replaced by electrolytic smt capacitors, rated higher than the tantalum ones, 35v 4.7uF, these will prevent some capacitors fireworks .
    There still are the LM317 "D" adjustable voltage regulators, a bit "ugly soldered".
    For that moment the only thing I had tested is that there exists communication with the device and if it recognizes the full authorization set.
    Tomorrow I'm going to try some eeproms to see if it works (more or less).
    Cheers, Mashu
  4. #679
    super jumbe's Avatar
    Livingstone
    Sorry to jump on the wagon but can some one confirm which one I should buy the X-Prog M or M35080V6 eeprom eraser program they both looks to be doing the same job or is one of them the latest invention, thanks for your time.
  5. #680
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    XprogM don't erase M35080v6 m8
  6. #681
    Dec 2010
    stuttgart
    can someone list some chinese suppliers for the x-prog m and the upa which work fine? So that these question is answered once for all time
  7. #682
    tehnosoftex's Avatar
    Romania
    Quote Originally Posted by pipmen View Post
    Well, as you already know, buying from China is a lottery, therefore your question has no answer
  8. #683
    near Strzyzow
    Price of UPA USB from China is the same as from Penko.
    Buy original UPA.
  9. #684
    Dec 2010
    i have dump for atmega64 + fusebits
    version 4.5 and 5.0 with all authorizations
    but only exchange
  10. #685
    Romania
    Default xprog m
    hello, that pictures are not really i bad condition.All pieces are like that.
    I have buy it to this xprog ,now i have questions like most of here.Hc05 Hc08 only reading,with security bypass.When modify value on hex and push write button said write error.Does anyone a solution.
  11. #686
    Is somebody knows what is the function without authorization "Development tools"? Something special?
  12. #687
    Harrycz44
    Guest
    Hello I buy x-prog m. revE ( USB) and M35080 programmer, x-prog work well ( I did CAS 2 BMW and EEProm 35080 ) M35080 programmer is fake or faulty item...
  13. #688
    exxl's Avatar
    Jun 2009
    Bosnia-Herzegowina, Bos. Krupa
    i have the x-prog-m with green pcb, but i have bought it before 2 years when it first came out with all authorizations.
    till now have done hc11 secured, hc05 from mb ezs secured, micronas, tms370, hc912, 35080, bmw cas.
    never had any problems with it
  14. #689
    Hi guys!!
    Well the ecutool xprom-m lasted only for one use , maybe it is one time use .
    Last Friday I tried to do an autoliv airbag unit with a 9508 eeprom and when I try to read it, it makes an strange noise, like if there is a faulty capacitor, arrrgggggg, after a lot of "silent device" it did a good read, but who tries to write and mess the real content ...
    Today when I arrive home I'm going to open it and try to find the faulty component and check some voltages...
    My nightmare begins, this is like an Russian roulette but with eight bullets .
    I'll keep you informed about my findings....
    Regardsssss, Mashu.
    Quote Originally Posted by mashupishu View Post
    Hi friends,
    Cheers, Mashu
  15. #690
    Hi again, I did some measurements on the board.
    As Zmann says on post #611 (page 41), I checked the IRF7316 having when the programmer is idle 17.9v on pins 1,2 and near 0v on 7 and 8. Also 12.3v on 3 and 4 pins and near 0v on pins 5,6.
    When I hit read on device programmer desktop the outputs of the two mosfets seems to be ok, near 18v on pin 7&8 and 12v on 3&4. The bi-color led starts green and then red, and then a vibrating sound appears until the window "Device is silent" apears and I close it. While that window is open the voltages are which I said on the mosfets outputs also the vibrating sound.
    I had observed too that some components get hot, not very hot but very hot for that short working time. They are marked magenta on the attached picture. What component is under the question mark?
    Also it seems that the dc/dc isolator is not tightly soldered, I'm going to check that. And as I said in a previous message the capacitors under the lm317 are 35v rated, maybe any is broken?, I really don't know.
    Have someone any idea about what will the problem be? (I'm trying to read a 95160 eeprom (also happens with a 95080, that was successfully read last week (no noise on the box).
    Thanks in advance for your support.
    Regards Machu.
