Page 76 of 85 FirstFirst ... 26667172737475767778798081 ... LastLast
Results 1,126 to 1,140 of 1264
Thread: X-Prog M
  1. #1126
    stefaudio's Avatar
    BULGARIA
    Idont now about upa but bilding dhis interface ic easi using PONYPROG
  2. #1127
    antwnhszr's Avatar
    macedonia is greek....
    I understand that I must have one more xprog-m
    thank you for your answer stefaudio
  3. #1128
    DK Veteran kevino's Avatar
    Slovakia
    Hi guys. maybe OT queastion but I need answer.
    I need to buy programmer for motorola chips. which is better ? x prog or upa. I will buy from china for testing, later maybe original. or please send me a link for china programmers.
    I have 1 immmobox from seat inca 1996 and 1 vw beta 5 radio. for tests.
    I found some xprog but
    Newest Version XPROG-M Programmer V5.0 with 18 Adapters/Boards - Free Shipping - DealExtreme
    Attention: this programmer is not good for Motorola chips. If you want do Motorola chips, please choose Motorola 908 programmer,705 programmer and 912 programmer.
    thanx for your advice
  4. #1129
    Jun 2012
    sorry for my english, I'm using a translator.
    I've got a serious problem, I tried many ways and can not resolve.
    I have a XPROG-M 5.0 with all releases.
    It worked perfectly until without knowing the risk I was running, I installed XPROG-box 5.4 on my computer when I was doing a reading and it asked me to update, register, and also update the certificate, the first two went well, less the certificate.
    I gave up and returned to the XPROG-M but since then it did not work anymore, whenever I try to read, he asks to update, by the way but never updates. I tried with the 4.2 4.5 5.0 and 5.1, in no fails.
    the version it is now is 1.7 build 14400 date 2012.05.01 status 5A373
    Can someone help me solve this problem?
  5. #1130
    Shmortz's Avatar
    in the middle of nowhere
    search in DK, there are many dumps for atmega, read threads, reprogram it and will be happy..
  6. #1131
    Dec 2010
  7. #1132
    antwnhszr's Avatar
    Default dump from my atmega64
    hi guys i ask you to help for us...today my xprog don't auth.
    mcu HC11.and i don't to now why.i read the atmega64 nad post here . someone have something dump for me?anyone haven't similar problem?
  8. #1133
    Top Poster + andy99's Avatar
    EUROPA
    Dump is wrong
    look at the forum solution
    Abritus AK400 BDM100 BMW-EXPLORER Beprog+ CLIP CarProg ETL ELM324 FVDI IDS J-Link GALLETTO3 SMOK K-SUITE Lexia3 MERCEDESINSTRUMENT MPPSv16 MVP ORANGE5 StarC4 TANGO UPA XprogM X-TOLL ZedBull
  9. #1134
    SergeyIg's Avatar
    Russia
    Hi all, somebody can tell how to expose Fuse, I already two Atmega have lulled.
  10. #1135
    Holtek's Avatar
    FuseBits configuration for ATmega64:
  11. #1136
    SergeyIg's Avatar
    Russia
    Quote Originally Posted by Holtek View Post
    That's it so I also tried, XProgom programmed and as a result have received fallen asleep Atmega.
    How now to write down Fuse? If at programming writes eror Devais.: Banghead:
  12. #1137
    stefaudio's Avatar
    BULGARIA
    Hi Sergei first of all tel us wot programmer you use to program atmega?
    And be veri veri carefull wit SPIEN fuse bit if you use PonyProg.The SPIEN hav to be enabled everi time you read and write atmega.SPIEN fuse=IN SISTEM PROGRAMMING
    If you disable dis fuse and write device after comunication is no longer posible by ISP onli bi HVPP(hig voltage paralel programing)
  13. #1138
    in PonyProg you canot enable/disable SPIEN fuse bit
  14. #1139
    Hi Stefaudio, I understand that his problem is not at that far. The MCU clock source has been configured wrongly. So, need an oscillator (not a crystal) of something freq. of 2-8 Mhz to connected to pin XTAL1 and now he can play on his programmer again.
    Quote Originally Posted by stefaudio View Post
  15. #1140
    stefaudio's Avatar
    BULGARIA
    Hi COSMIND yes you cant enable/disable SPIEN(wit PONY)
    But if SPIEN fuse is enabled(in first place)in atmega,and you load some compled project file in which SPIEN is disabled and program dhis file this is end of serial comunication with atmega,ok but if you load same bad file with disabled SPIEN and befor***1077; you make mistake to loadit to mcu you can reed original fuse bits(where spien is activ) and dhere spien fuse is enabled just push OK buton and programmer will program rigt for you fuse bits.
    I am not so good with explanations but i hope you understand woth i mean
    REGARDS STEFAN
