That was my problem with UPA/Pony too on my early day.
Find an oscillator, not just a X-tal, of 4-8 Mhz. Power it up and feed the output to mega64 pin Xtal1. Good to pay attention on too strong output power of a big oscillator.
Continue as usual with ponyprog
It depends what is set to cksel fusesif its ext RC then need to connect resistor and capacitor (RC circuit) or ext. clock then you need to feed square wave to xtal pin.. that clock can be made from 555 timer chip
Quite hard to check OSC without oscilloscope but I'm still quite certain the the cause is from wrong clock bits because Pony does not allow you to set SPIEN. Can to try with one more OSC.
Yes, you can use the new one, with working dumps
with new atmega64 everything ok. Thanks!
how set up Lock bits after write flash/eeprom to atmega64 with ponyprog?
Its in the tut here:
http://www.digital-kaos.co.uk/forums...repair-314041/
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
setup (configure) lock bits, to lock or to unlock?
to lock: open config window> read> tick lock1,lock2> write> done
to unlock (after locked): no way (but some of the way) unless to erase chip which means eep+flash gone too but the chip become unlock state.
i want to know in 9s12 from mercedes ezs with 1l85d mcu secure how you read it ?5 cables or and xlcs cable and 2 ground.have any photo.i don t understand the 2 pairs cable in twisted?if have any photo it is good for me.thanks
