Page 72 of 85 FirstFirst ... 2262676869707172737475767782 ... LastLast
Results 1,066 to 1,080 of 1264
Thread: X-Prog M
  1. #1066
    H.Wessel's Avatar
    Jul 2010
    Quote Originally Posted by bolonc View Post
    100% fake! Changes to the V5.0 PIC to V5.3
    xD Nice work
  2. #1067
    DK Veteran gjuzel's Avatar
    Nov 2011
    (North Macedonia)
    Default x-prog m v 5.0 clone
    hi.I cant write and read ..motorola hc05..hc08 and hc11.I did Authorization.please help...thanks. x-prog m v5.0 (CLONE)
  3. #1068
    what message do you have ?
  4. #1069
    Nov 2011
    (North Macedonia)
    hi.I Can write read motorola hc05...hc08 and hc 11 ???? I did autorautorization but still can not read and write hc 05 hc08 hc11.help.thanks.
  5. #1070
    Dec 2008
    Hi can someone sum up what this tool can be used for in laymans terms, I understand it can be used to clear crash data from airbag EEPROMS but what else do people use it for?
    Ive heard people on here say they make there living or a good wage using this tool just interested to see the sort of jobs they do with it other than airbags.
  6. #1071
    Member paddyp's Avatar
    Aug 2009
    Hibernia
    Keys,dash,immo,tuning,fap off,virginisation of ecu etc. not to mention fixing your broken clones from China of course you need to have other programmers and software to complement it.
  7. #1072
    tatop's Avatar
    Dec 2010
    italy
    Default Xprog m "connection error"
    My Xprog m v.5 clone today show "connection error" with any micro and chip...and all family dont autorizhed... have solution?
  8. #1073
    stefaudio's Avatar
    Nov 2009
    BULGARIA
    hi m8 tatop solution allreadi on the forum just reed
  9. #1074
    tatop's Avatar
    Dec 2010
    italy
    Quote Originally Posted by stefaudio View Post
    Hello Stefaudio ... I read all the forum but can not
    find the solution to my problem
    Can you give me a help?
  10. #1075
    alfons37's Avatar
    Sep 2009
    Default i have same problem
    i hade same problem, i change to version 4.5 and try set com port number under options.
  11. #1076
    tatop's Avatar
    Dec 2010
    italy
    Quote Originally Posted by alfons37 View Post
    you have solved??
    how??
  12. #1077
    Oct 2010
    portugal Coimbra
    Quote Originally Posted by Bllinda View Post
    I have a cloned x-prog-m V5.0. What did you mean by bidirectional line, BKGM?
    Does anyone have the exact connecting scheme, HC08 AZ32(J66D)?
    you have to lift 9v pin vppr. and it works fine
  13. #1078
    Top Poster medsa's Avatar
    Mar 2010
    please can some one show or drawn this plate diagram for 908 mcu
    and from where should come the Oscillator connection from the x prog
  14. #1079
    Nov 2011
    (North Macedonia)
    x-prog v.5.0 clone.......from DH GATE seler mikehepyfactory the best seeler...autorization see in my screen shoot...
  15. #1080
    Jul 2011
    Quote Originally Posted by gjuzel View Post
    Hi!!!
    If all connection ok when try to set oscillator 16KHz!
    I had same problem in hc 11 and it's ok after set the oscillator!
    I think that's your problem!
