Page 9 of 85 FirstFirst ... 45678910111213141959 ... LastLast
Results 121 to 135 of 1264
Thread: X-Prog M
  1. #121
    Jan 2010
    hk
    Quote Originally Posted by adam28 View Post
    Do you have a link mate? so all our friends can check it out.
    Do you own this company.Or you on a percentage of what you can sell?
    If you are learning to use these tools then you will be able to give some sort of support, which is good.
    hi, m8, sure for support is no problem, let's share experience is OK
  2. #122
    DK Veteran sl4ck's Avatar
    Jan 2010
    Quote Originally Posted by obdmaster View Post
    Are these pictures of your actual product m8, as ive seen them on download from tekionics. Like does your product come in plastic suitcase as original does. And is the picture of the xprog-m a picture of your product. As my clone xprog has two sides where the edges are rounded not at 90 degrees like original. And mine doesnt have the labels on the leds.
    Attached are the pictures from tektronics website they look the same as obd2masters, check em out.
    M8, does your clone from ECUTOOL has the transport plastic case?
  3. #123
    obdmaster's Avatar
    Never never land
    Thumbs up
    Quote Originally Posted by sl4ck View Post
    No m8, it doesnt. the one this guy has looks the same as the more expensive one from tektronics m8.
    Programmers XPROG-M Programmer
  4. #124
    Jan 2010
    hk
    Thumbs up
    hi, M8, clear pic just made from our engineer team, AL case main unit with suit case.
  5. #125
    Jan 2010
    Quote Originally Posted by obd2master View Post
    So, what's your site and price for full authorizations and adapters order?
  6. #126
    DK Veteran stevan's Avatar
    Dec 2008
    Bosnia
    HI, M8, definitely NO, ECUKEY simplay cloner, I can confident enough to make one deal with any guys on the XPROG-M, 1500USD as I said to m8 obdmaster, if our XPROG-M works perfect as TMT, the 1500USD is mine, if no, then money is yours . below pictures share with you.
    I you want to say that ECUKEY Xprog ios not ok?
    I have order one for testing.
  7. #127
    Jan 2010
    hk
    hi, sl4ck, please refer to Programmer XPROG-m Motorola 68HC05 , 68HC08, 68HC11, 68HC(S)12 XPROG [AS800XPROGM] - €1,234.65 : Store.autosvs.com, or you can refer to our sales staff on prices
  8. #128
    Jul 2009
    i have xprogm 4.5 clone and i work by rs232 with power 12v and all funcions work ok, full autorisation, by
    usb many times too low power.
  9. #129
    obdmaster's Avatar
    Never never land
    Quote Originally Posted by mavi View Post
    I use mine by usb and 15volt exteral dc power supply works ok
  10. #130
    Nov 2009
    can anybody show real pictures connecting xprog-m to ews? i need to see the connection diagram. i don't what is wrong with my device. thank you
  11. #131
    bricolo's Avatar
    Jul 2009
    france
    hi
    is this seller good seller and what do you think
    about they product quality ?
    OBDAUTO--BMW OPS VAG-COM,Tacho Universal,KWP2000,BMW Scanner,BMW Carsoft,ELM323,Code Reader,Can-bus
    I want to found a seller able to sell all automotive
    product i need ( diagnostic, key programmer, xprog- chiptunning tools.....)
    thank
  12. #132
    Jan 2010
    USA
    Quote Originally Posted by stevan View Post
    Hi did you get your programmer from ECUKEY, I want to buy one from him just want to know if works OK.
  13. #133
    Jan 2010
    USA
    Default XProg-M
    Do you have the ARM Micronas authorisation? and what is your software version? Can your Xprog-M be updated with newers softare?
  14. #134
    obdmaster's Avatar
    Never never land
    Thumbs up
    Quote Originally Posted by anyscancn View Post
    here you can find very good customer service and tech support .sure the quality is most importent.
    www.anyscancn.com
    but will your xprog-m update m8
  15. #135
    Dec 2008
    Bosnia
    Well don't try to update it will damage firmware inside prog.
