Hybrid View
    Apr 2016
    Default MB W203 EZS 203 545 05 08 HC08 correction problem with R270
    Hello!
    I have problem with mileage correction on this ezs. I read it with R270 and calculator didn't detect mileage(1J35D-0807(00)EEP orig.BIN),so i used NYO, it showed 814630, and i corrected it to 175124(1J35D-0807(00)EEP corrected.BIN). But when i connected it to the car, i jumped back to original mileage 202xxx. So i read ezs again(second.zip) NYO shows 175124...
    What could it be?
    I also corrected cluster to same mileage.
    First.zip
    second.zip
    you have read the wrong mcu
  3. The Following User Says Thank You to vageric For This Useful Post:
    alkaskad (12th August, 2016)
    Apr 2016
    Its 1J35D mask, mcu is on downside of the ezs where the plugs are....
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Maybe you don't read NYO4 instructions.
  6. The Following User Says Thank You to lupu_sandu For This Useful Post:
    Apr 2016
    You were right guys!!! Wrong MCU!!!!
  8. #6
    Jun 2020
    Hello, alkaskad i have the same problem with r270 can you tell me the right pinout and which mcu i should connect the programmer
