Results 1 to 15 of 15
    Feb 2011
    Default 2008 Land Rover LR3 KPH to MPH Conversion
    Anyone familiar with the anti theft (immo) on this model. Vehicle is from Canada (KPH) and I am looking to convert it to MPH. I already have another instrument cluster from a local recycler but it won't start with it in the vehicle. I was thinking of taking the needles off and swapping the overlay however I can't figure out the digital odometer, it won't go to miles, however you can change the center display to Miles or KM. What is the easiest way to solve my problem?
    lush29's Avatar
    Oct 2015
    Swap eeprom and job done
    Sent from my SM-G925F using Tapatalk
  3. The Following User Says Thank You to lush29 For This Useful Post:
    JandJSpeedShop (13th August, 2016)
    Feb 2011
    Quote Originally Posted by lush29 View Post
    Hopefully will get to that later today, I appreciate the help. Now here is to hoping the EEPROM is on the back of the board so I don't have to deal with needles
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by JandJSpeedShop View Post
    Is at the back. No need remove needles
    Feb 2011
    Negative on the EEPROM swap. I swapped over the EEPROM from the Original to the recycler instrument cluster and the vehicle is now a no start and the display is now in KM. I might be able to make this work if someone knows which byte controls weather miles or km is read out on the LCD display
    clusters's Avatar
    Mar 2015
    Canada
    Put the original eeprom back in the MPH cluster, then post in the Immo forum on how to reprogram the Immo for a dash swap.
    Feb 2011
    Quote Originally Posted by clusters View Post
    Really not any hardware I have access to currently. I know I can pull the needle and swap the overlay, that just leaves me with figuring out which byte controls weather KM or miles is displayed on the LCD, I know the original cluster without the EEPROM soldered on displays ERROR, but it says miles and not KM, so maybe I am looking for a byte that is added instead of FF
    lush29's Avatar
    Oct 2015
    I did one of them clusters an few months back. Customer bring me km cluster and ori on the car was milles. I swapped the flash because at that time i thought miles are in flash so i swapped the flash and still milles. Then eep and job done. What eep you have on your clusters??
  10. #9
    Feb 2011
    The one had a 35080 and the other a 080dowq
  11. #10
    lush29's Avatar
    Oct 2015
    Well they are not the same....
  12. #11
    Feb 2011
    Thought they could be interchanged? Because the mileage did move over and display when I moved the EEPROM over.
  13. #12
    lush29's Avatar
    Oct 2015
    Then move the flash also....and that should work with no prob
  14. #13
    Feb 2011
    Well aside from moving the flash it would be much easier to disassemble both and just switch the overlays/faces
  15. #14
    lush29's Avatar
    Oct 2015
    And what you gone do with the digital display?
  16. #15
    Feb 2011
    Success, moved the MPH overlay onto the original circuit board, removed the KPH EEPROM and installed the MPH EEPROM from the wrecking yard cluster and programmed the mileage. The center display can be changed in the preferences from metric to US it was the right display that changed with the EEPROM. Job complete and the customer is happy
  17. The Following User Says Thank You to JandJSpeedShop For This Useful Post:
    lush29 (17th August, 2016)
