Results 1 to 15 of 26
    Nov 2015
    Default MC9S12DG128 - 3L40K - problem with reading UPA, Carprog and Xprog
    Hello. I need to read dump from MC9S12DG128, mask 3L40K. It is from Astra H CIM module. I try with UPA, XPROG and CARPROG - no result.
    I connected it like in XPROG documetation: 23 -BKGD, 40 - GND, 41 - VDD (+5V), 42 - RESET. I think it is correct.
    CARPROG:
    In carprog i am using A10 cable.
    Red --> 41
    Brown --> 40
    Blue --> 42
    Gray -->23
    Oscilator is AUTO. When try to read there are only 5 attempts to read and nothing. The same with or without external power.
    UPA:
    In UPA i connected it:
    9 --> 41
    7 --> 42
    5 --> 40
    6 --> 23
    Oscilator AUTO. If reset is not modified i have error: "Reset High Error". If I lift reset there is: "Device not respond". The same situation with USB power and external power.
    XPROG:
    No matter with adapter or without. Still error: "bootloader initialising error. Can`t to access BDM"
    Please, help me. What I do wrong?
    Feb 2013
    MCU is secured.
  3. The Following User Says Thank You to Joe12345 For This Useful Post:
    stachu22 (13th August, 2016)
    Nov 2015
    Ok, maybe. But what I must do to read this MCU?
    Feb 2013
    Read with Xprog, look in menu for secured 9s12.
  6. The Following 2 Users Say Thank You to Joe12345 For This Useful Post:
    houdiag (29th December, 2018), stachu22 (13th August, 2016)
    Aug 2015
    You need also Connect extal and ground
  8. The Following User Says Thank You to offsystem For This Useful Post:
  9. #6
    Nov 2015
    Ok, i read it like secured MCU. There is a BIG progress, connected to MCU and read eeprom. But during VERIFY there are a differences in some bytes.
    I connected it like:
    Is need 12-14 cm EXTAL twisted with GND?
    I dont remove EXTAL from PCB but only remove capacitor after them.
  10. The Following User Says Thank You to stachu22 For This Useful Post:
    MAKS79 (5th February, 2021)
  11. #7
    Aug 2013
    Macedonia
    make disable auto verify in xprog
    and read the eeprom from mcu 2 times then check dumps for difference
  12. The Following User Says Thank You to nenadgorgi For This Useful Post:
    stachu22 (14th August, 2016)
  13. #8
    Nov 2015
    I have two dumps:
    3l40k.rar
    All time when I red there is some differences
  14. #9
    Aug 2015
    Lift extal and rst, check soldering xprog can read this mcu 100℅
  15. The Following 4 Users Say Thank You to offsystem For This Useful Post:
    andfonte (14th January, 2018), baskom (20th April, 2020), okm (24th February, 2018), stachu22 (14th August, 2016)
  16. #10
    Nov 2015
    Thanks for all. Problem is solved There wad bad connections between PINs from BDM adapter and my cables. When i squeeze cables reading is OK. Reading is good without lifting any pins of MCU. One more Time, thanks
  17. The Following 5 Users Say Thank You to stachu22 For This Useful Post:
    houdiag (29th December, 2018), luis12 (20th August, 2016), mkopytekchi89 (30th August, 2019), nenadgorgi (14th August, 2016), specnaz (3rd November, 2017)
  18. #11
    Nov 2015
    Quote Originally Posted by stachu22 View Post
    Which programmer do you manage to read it?
    Greetings
  19. #12
    Aug 2016
    Ukraine, CV
    I think it was XPROG
  20. #13
    Nov 2015
    Hello one more time. I have still problems with xprog. After last reading I dont use my xprog. Today i try to read one more time mask 3L40K and... nothing. Connected the same as before. When i try to read this MCU there is CHECKING DEVICE and green LED on xprog, after few seconds there is INITIALIZING DEVICE, led change on RED and info DEVICE IS SILENT. RED led is still ON, turn of only when i disconnect USB cable. I also try to read the same MCU as at first but the same situation. What can be wrong?
  21. #14
    Nov 2015
    Problem solved. I dont know why my xprog works only with one USB cable. I test 7 USB cables and nothing, only when i plug cable from xprog set main unit works good
  22. #15
    Mates , XCLKS green need to be soldered on EZS or not with xprog and if YES where ?? Because 9S12 manual R260S claims DO NOT CONNECT GREEN WIRE !
  23. The Following 2 Users Say Thank You to basim88 For This Useful Post:
    DAVID8HENRY8 (24th June, 2017), joejam (22nd November, 2019)
