Results 1 to 4 of 4
Thread: oil sump socket
    DK Veteran chris31560's Avatar
    Feb 2010
    wigan
    Default oil sump socket
    hi guys, just been under car to see wot size socket I need to remove the sump plug and found it was not the 8mm socket I thought it was, the sump bolt is defo square but a tinny bit smaller than a 8mm square socket, so I was thinking 7mm but they dont seem to sell them, could it be a 5/8 or something like that I need? any help would be great...
    oh and by the way I have a citoren xsara picasso 1.6 petrol 2006..
    cheers..chris........
    A LITTLE THANX GOES A LONG WAY
    Sep 2008
    it should be 8mm if square rusted,crap inside or road contact may have made it smaller.
    Feb 2010
    wigan
    ah, I thought that might be the case as the 8mm socket I have does go in about half way then stops, so wot I will do is clean out the square best I can and lightly tap the socket the rest of the way in until it makes proper contact.
    cheers bud................c
    Sep 2008
    yep muck can fill in the hole and an electrical screwdriver moved around inside should see crap coming out.
  5. The Following User Says Thank You to cactikid For This Useful Post:
    chris31560 (15th August, 2016)
