no experience with this ECU and EGRoff??
Hi, I tried to make EGRoff in SID801 but still have some problem.
I made modification with setting of one area to zero but car has problem with this mod. After that I found information that is necessary to disconnect solenoid valve which control EGR. After that car works fine without limp mode but in the ECU is new DTC P2143 from solenoid
please, is it possible to make EGRoff on this ECU without DTC in ECU?
I attached original + mod.
even you remove DTC soon car will be back to you with the same problem
DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
The best solutions are with disconnect sensors. Can make it with solenoid off
which sensors?
vopi (18th August, 2016)
thanks, I will test it soon
