Results 1 to 2 of 2
    Junior Member welshbhoy's Avatar
    Aug 2008
    Default Getting TomTom to run on an HTC TyTN (hermes200) help
    I have a HTC TyTn and am looking to run TT on it. Does anyone know how I can do this?
    I know I need a seperate GPS Reciever, which I have, a Holux 240slim. I just need to know which version of TT to use and how to pair the devices and also the satellite configuration for running TT on the TyTN.
    Any help or advice really appreciated.
    thanks.
    Aug 2009
    You can use "TT7_910.9185_VGA black.cab" which is the original install file. Install it in to memory card , Then replace the " navigator.exe" with cracked navigator.exe so it reads the maps.
    You need to copy the maps into the root of memory card, although sometimes depending on the machine you might need to have the maps in "My Documents" folder, if thats the case you need to create folder in memory card called " My Documents" and edit registry so phone uses the My Documents in memory card.
    If you need more information let me know.
    You can use the bluetooth gps in tomtom gps settings.
