Zgemma H.2s Twin Tuner
  • charlieboy1
    • Aug 2016
    • 3
    Hi There, Im looking for the latest vix image for my zgemma H.2s. Think its called sky Q skin fluid. Can anyone help me with this?
    C
  • martin035
    • Apr 2014
    • 1308
    The latest openvix image 4.2.1 doesn't work on a Zgemma's, you're better off looking for alternates like openatv, then put the sky Q skin on, or if you want an easy option just try this image;
    This Backup Image is for the Newer H series of Zgemma Satellite receivers, it will work on the H.S and H.2s and confirmed working on the H.2H by Hadron @post #116 (requires additional setup for cable see post #119) but hasn't been tested on the H5 Openatv5.3 Backup Image with New improved Sky Skin, OTA update safe ?
    • charlieboy1
      • Aug 2016
      • 3
      Cheers mate. will give it a go..
      • lincsat
        • Jun 2008
        • 1228
        http://www.digital-kaos.co.uk/forums...3-Backup-Image
        Not actually tried the 4.2.1 on a H series ZGemma, they are different to the 1st Gen (sh1). ViX4E2 does now officially support the ZGemma H3 boxes, so worth a try
        • martin035
          • Apr 2014
          • 1308
          I'll have to give that a try, once I finished testing openLD on the zgemma H series. One question what EPG plugin are you using on vix4e2? as I was wondering if crossepg 0.8.1 was fully compatible?
          • lincsat
            • Jun 2008
            • 1228
            Yes, it has CrossEPG. It's also fixed the initialization of SD problem, although I still use Partition Wizard on my PC for that.
