ON TOPIC:-
as it is new, does it need to see tge engine oil dropped & refilled to clear?
ON TOPIC:-
I don't realy know its my first jeep with scr
Envoy? de mon SM-G928C en utilisant Tapatalk
MH crystal ball tells me that under the hood sleeps an vw engine....
A failure will not appear till a unit has passed final inspection
Meat-Head (20th August, 2016)
Fiat i think
Just guessing here,
IF adblue was added with ignition on and instrument panel software was made by an engineer, then you may end up with this situation,if removing battery leads didn't work,try with diag on dash and hit whatever you can eg actuator test,adapting whatever you find there,erase fault codes even if there aren't any...
Leave the battery leads off for 24 hours(works on some older cars)
Jump on one leg around the car...
Meat-Head (20th August, 2016), prochipper (23rd August, 2016)
ON TOPIC:-
Can you drain the ad-blue (drill hole in tank) then let it flag
"low on pig pish" & then see what happens
rideon (20th August, 2016)
Will try that today
Anything in the handbook for the end user on filling adblue
As u see adblue level is 100%
Did you drain the adblue tank?
what abiut tweeting @jeep
I will drean tommorow and let u know
Well, any news![]()
Meat-Head (28th August, 2016)
Nop i contacted dealer in spain
They have no solution.
They told me in 2 days they will have answer from jeep fiat in italy..
bonecrusher (28th August, 2016), Meat-Head (28th August, 2016), rideon (24th August, 2016)
