mikajna (28th August, 2016)
Guys does Some one have experience with Clone gambit,
My tool always comes with error write error 7.
I only tested on 7935 transponder.
They are blank,new.
I bought this tool for only one Car but now it fails on me .
Is there Some other soft available or should i rework hw.
Any help is welcome
Anyone guys,
Give it a rest, with this device, one of the oldest facilities of scorpio, only permanent code, abandoned the project, then released tango put to the cabinet in remembrance, as I
Thanks for that response, i know its an old tool.
Like i Said i Will need it only for 1 job.
Need to make a key for a w163 with eam module.
Thank you.
gambit can do this job 100%. you have to read your pcf7935 than clear with gambit. after that load your dump and make transponder ready for start.
this is how should be pcf7935 after clear. maybe you have some bad transponder, try with another one.
honingkoning (23rd August, 2016)
Guys what other not too expensive tool supports eam module for a w163.
I dont do lot of keys otherwise i would have bought tango or Some like that
Did you try another Blank pcf..
Iam sure clone gambit do it..
But iam not sure if your gambit clone have problem
This tool can do also
Last edited by vanos batam; 28th August, 2016 at 12:31 PM. Reason: Forgot attached picture
