Results 1 to 10 of 10
Thread: UPA Question
    justy22's Avatar
    May 2009
    UK
    Default UPA Question
    When I open a dump from file I then select 93c56 from menu bottom 3 lines disappear, what am I doing wrong here
    all help much appreciated
    Dufner
    Johnner's Avatar
    Éire
    Justy,what car and what eeprom was it read from ?
    justy22's Avatar
    May 2009
    UK
    im trying to fix dump on my scenic 2 93c56 using dump of here open it with upa but when I select 93c56 last 3 lines disappear
    Dufner
    Johnner's Avatar
    Éire
    Can you give me link to file ? It should only be 256 bytes in size...
    justy22's Avatar
    May 2009
    UK
    this is file here
    Aug 2015
    Tu archivo me da en km 32246km
    your file gives me in km
  7. The Following User Says Thank You to juancho18 For This Useful Post:
    justy22 (20th August, 2016)
    Dufner
    Johnner's Avatar
    Éire
    That's because it's byte swapped...File looks to be correct size though
  9. The Following User Says Thank You to Johnner For This Useful Post:
  10. #8
    justy22's Avatar
    May 2009
    UK
    ive managed to get dump working but display in French and speed in KM and fuel gauge flashing does it need configuring with clip
  11. #9
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Soft in screen above does it
  12. The Following User Says Thank You to teerak2uk For This Useful Post:
  13. #10
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by justy22 View Post
    your dump in english & Mls not sure about gauge though
    scenic_2008_93c56 eng mls 63101km.rar
  14. The Following User Says Thank You to teerak2uk For This Useful Post:
