Results 1 to 8 of 8
    Nov 2015
    Default ktag vs bosch edc16c39 opel/suzuki
    Hello, i have troubles reading edc16c39 from opel zafira 88kw 2011, suzuki sx4 88kw, before had same problem with opel astra 1,7cdti...
    is it normal that ktag(reworked) will not read this ecu? says this microprocessor is not recognized (mpc500 motorola). so what tool is needed to BDM those if ktag is no-go? xprog? bdm100? any other cheap and realible solutions?
    Sep 2010
    RO
    BDM100 should do it. I did a few some time ago.
    Jun 2012
    you need to read BDM mode. very easy to read,
    you sure your probes on correct, and power ?
    Clone k tag works fine BDM, well mine ok
    BDM100 and fgtech all work ok,
    im sure you must have a probe wrong, make sure all probes good contact,,,,
    Nov 2015
    yes all connections checked very carefully, all was soldered like needed to be, power supply used 12v 4a not cheap that come with ktag, and this did not work on 3 ECU of this type... software trasdata, gives error "unindentified microcontroller e000020"
    ktag tested and worked on edc17c46
    Increase the voltage to 13.5 volts
    Nov 2015
    blazej1200 you think with 13,5v "unindentified microcontroller" error will be gone?
    Jun 2012
    sounds like your tool.,... BDM ~~~~ no work,,,
    never played upping volts. just works on 12. 12.5 V
    Jan 2017
    I'm facing the same problem, how to solve it ??
