try this way and have fun
Hi, I bought a 06A 906 018CJ ECU wich is supposed to be M3.8.3 wich should be flashable. The Flash chip is 29F200AB But with MPPS i cant write to it. Im just getting MPPS error.. My tool works for other ECU like Me7.x.x and so on.. I know it works in those cases.
Could this 29F200AB chip be a non flashable chip?...
Col19 (13th October, 2020), Jandro1point8T (8th March, 2020)
dissolder flash and do it on banc with other programator. some of this ecu cant read ore write.
you are missing +12v on pin 43 on the ecu
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination.
I have the Famous pin43 connected to +12V an i have double checked all connectors with multimeter. I have 12.5V from a bench battery connected to a stabilized source.
Im starting to think that it might be the immo? Security Access?
@jolidj This is not the PLCC44 chip its the 29F200AB chip.. Ive read tons of threads where ppl make this work? OR have i been disinformed,, hmm..
I flashed exactly this ECU - 06A 906 018CJ on friday. Immo is not the issue.
Thanks.. Saved me some headace.. ECU Programming Voltage Missing is still my problem.. any suggestions?
i flashed many of these ecu's .. programming voltage missing is always pin 43 never had problems with immo
(\__/)
OMGFG... I installed MPPS 13.02 on my Win7 Machine instead.. and you know what!!! I WORKS !!!!!!!!!! Thanks anyway guy.. im impressed of quick answers and good response.. i gotta hang around in this forum more..
