Results 1 to 10 of 10
    pike's Avatar
    Sep 2013
    Default EDC16C39 EU5 EGR OFF Issue
    EDC16C39 1.6 Multijet 16V
    HW: 0281017012
    SW: 1037514046
    I need help EGR maps location or removing the valve with disconnect.
    Sometimes I get DTC's: P0487, P0490
    konq100's Avatar
    Oct 2013
    Sofia, Bulgaria
    Hey if you not have another option please check this file. Not tested but should work.
    Don't forget disconnect EGR connector.
  3. The Following 2 Users Say Thank You to konq100 For This Useful Post:
    pike (22nd August, 2016), stanislav georgiev (1st October, 2016)
    Aug 2016
    I need the same information for the same ecu but diferent software.
    Can I see the file?
    pike's Avatar
    Sep 2013
    Quote Originally Posted by konq100 View Post
    Thanks.
    But file not work.
    Need help to delete EGR in this ECU.
    Default fiat
    Your file egr switched off
  7. The Following User Says Thank You to blazej1200 For This Useful Post:
    pike (1st October, 2016)
  8. #6
    carbon7319's Avatar
    Aug 2011
    Macedonia
    When you unplug connector from EGR , what DTC you hawe exept P0487, P0490 ?
  9. The Following User Says Thank You to carbon7319 For This Useful Post:
  10. #7
    pike's Avatar
    Sep 2013
    Quote Originally Posted by carbon7319 View Post
    When unplug connector from EGR DTC's: P0409, P0487, P0490
  11. The Following User Says Thank You to pike For This Useful Post:
  12. #8
    carbon7319's Avatar
    Aug 2011
    Macedonia
  13. The Following 3 Users Say Thank You to carbon7319 For This Useful Post:
    bobolin4o (23rd August, 2016), pike (23rd August, 2016), stanislav georgiev (1st October, 2016)
  14. #9
    Sep 2016
    any one can help me hoe to find egr pn this map?
  15. #10
    pike's Avatar
    Sep 2013
    Quote Originally Posted by pedrogabri View Post
    You, may, have lost.
    in this topic the solution for other ECU.
  16. The Following User Says Thank You to pike For This Useful Post:
    konq100 (1st October, 2016)
