Results 1 to 3 of 3
    Dec 2010
    Default sprinter start error help
    Hello. need help with 2000 year sprinter .cdi. start error problem. I tried with immo1.3 but no works
    Immo : Temic .026 545 1732. ECU A611 153 1479.
    I attached both immo and ecu files
    jolidj's Avatar
    ITALY
    for work the repair solution you need all ok.immo box ok, ecu ok transponder antenna ok.
    if you dont have sysstem work you solve only with immo off emulator.
    Dec 2010
    immo ok, ecu ok, transponder ok. only antenna has suspecios. Where does go antenna wires? Someone has wiring ?
