Page 31 of 125 FirstFirst ... 2126272829303132333435364181 ... LastLast
Results 451 to 465 of 1863
  1. #451
    Nov 2012
    Ukraine
    andrym3
    Z9HQUF52SV4VRECLFRPUD5EWH3XD6HFQ3MJGN4CTFYCXZPSN9P NHHVHR67NYEQQL94YFSX3S
  2. The Following User Says Thank You to Andrey1842 For This Useful Post:
    andrym3 (8th April, 2017)
  3. #452
    Feb 2017
    Netherlands
    Just finished with flashing my carprog 4.74 to 8.21 firmware.
    Can someone please help me with an activation code for HW id: B9826-D080F-CA006-AF080
    Thanks in advance!
  4. #453
    Nov 2012
    Ukraine
    DieselManiac
    44DBKFKGBBTLPNX9GNTAS5NP6P8E79EVNAT7394EGD3F6Y7NHN 4CQWE79XPQ3F56LS7ED9EK
  5. The Following User Says Thank You to Andrey1842 For This Useful Post:
    DieselManiac (9th April, 2017)
  6. #454
    I've updated my firmware to 8.21.
    Someone can get my activation code.
    My ID is: 8BB66-D0882-24006-AC4BE
    Thank you
  7. #455
    Oct 2014
    romania
    can someone give me the bin dump to flash my carprog to 8.21
  8. #456
    Nov 2012
    Ukraine
    BWF
    XK2BN3WEHMTAMHK8SRR2U8YSB6FG95CSRCPY3WFPMMY6UUM3PH FBSUGMC2SNLQXKSY9RHKFV
  9. The Following User Says Thank You to Andrey1842 For This Useful Post:
    BWF (8th April, 2017)
  10. #457
    Aug 2013
    uk
    would it be possible for a activation please
    Thank you
    If i helped.... please dont forget to press the THANKS + REP buttons .
  11. #458
    These codes to activate, exactly what is it used for?
    To update the carprog remotely?
  12. #459
    Aug 2013
    uk
    Quote Originally Posted by BWF View Post
    activate for online use.
  13. #460
    Nov 2012
    Ukraine
    thayer201
    A7ZFG4FS9NQJAAQCCPAPEH53LHYTRPAM7RC3GBSBMRZG85SLLF PPJZGQXC76W54TWN
  14. The Following User Says Thank You to Andrey1842 For This Useful Post:
    thayer201 (9th April, 2017)
  15. #461
    Aug 2013
    uk
    Quote Originally Posted by Andrey1842 View Post
    thayer201
    thank you ............ but i seem to have a problem
    carprog deice not seen in device manager and also carprog software
    i understand that the driver should install for this after the activation but after activation carprog software jus open as it should but still device not seen.
    any idear what the issue is.?
    im running on win 7 x64 is that the issue x64? needs to be x32
  16. #462
    Nov 2012
    Ukraine
    Quote Originally Posted by thayer201 View Post
    The driver must be installed even if you do not have software for carprog.
    If the driver is not installed, then probably your device is broken
  17. #463
    Aug 2013
    uk
    brand new device version 8.21 online - pluged in green light on carprog but not recognized pc doesnt detect it...
    either way i will rework/reflash it..... thanks for the activation anyway..
  18. #464
    I have the activation code, someone can explain how to activate the carprog
    I want to read a golf dashboard 6 but there is a bootloader error after trying to connect via CAN.
    I do not know if it is activation failure or that carprog can not read
  19. #465
    Oct 2014
    romania
    need activation please ,thank you rep+thank
    B2C26-D0868-A8BBA-6AE38
