file is terrible but shouldn't kill the turbo
did u fit new or used turbo , cant see a file doing it tho
did u check oil feed and return pipes
problem is your turbo.not pressure oil inside. if turbo is ok you can joke from maps whith hight pressure.
ALL TUNING.
THE BEST OR NOTHING. THANKS + REPUTATION .
turbina after 10 minute
your file is not very well but shouldn't kill a turbo
DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
Have you tested oil pressure? Maybe you got oil from old turbo, into intercooler, pipes, intake and this can ruin second turbo if you didn't clean all this
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles) on allmost every petrol
common problem with these cars, check oil pomp and piping.
Kutscher (14th December, 2019), Martello77 (21st May, 2017), p38 (30th August, 2016), teerak2uk (30th August, 2016)
you have low pressur inside maps. your problem is on car.
ALL TUNING.
your better check shaft on oil pump, it is probably looks more like round then hexagon
