Results 1 to 9 of 9
    Fec001's Avatar
    Default Volvo S60 2.4 Turbo tuning
    Anyone here experienced with these volvo engines?
    Car is S60 2.4T 200HP MY2001. Engine code: B5244T3
    We put turbo and injectors from Engine 2.3 turbo B5234T3 250HP.
    Can Someone help me with a good tuning file for the new parts?
    Car was on dyno and measured 217HP
    Russia
    Upload stock file.
    Have you tried to run the car after it?
    If you want I can send you a stock file for 2.3T 250HP and make tuning file for the car.
    Is the car manual or AT?
  3. The Following User Says Thank You to konopel For This Useful Post:
    Fec001 (1st September, 2016)
    Fec001's Avatar
    Car is manual. We tried car after put new parts on the engine, works ok and measured 217HP on dyno. Here I upload stock 2.3T file and the car's stock file.
    I think it's enough to copy injection and boost maps from 2.3T to 2.4T file and "riase" some values.
    Russia
    One more question. Have you tried to run the car using software from 2.3T stock?
    I have changed some maps. Try it.
    But I think you should test stock 2.3T file at first.
  6. The Following User Says Thank You to konopel For This Useful Post:
    Fec001's Avatar
    Don't try 2.3T stock flash because I think it will not start the car because of immo. But I will try then...
  8. #6
    Russia
    IMMO is in EEPROM
  9. #7
    Jan 2017
    I've got one of these, did you manage to tune it?
  10. #8
    Sep 2016
    immo in eeprom but when you write other maps to flash cars maybe not start, tested to many cars
    FILE SERVICE
  11. #9
    Jan 2017
    Quote Originally Posted by voltechcar View Post
    what did you use to read immo?
