hi. i have lost all my encrypted channels. i dont know what i have to do with flash fxp to get them back. i have done everything else but need to update the cccam config with channels list and what servers im using but dont know where to look or really how to use it. i connect to the dreambox with it but just get the files list and dont know where to edit or what to edit. cheers steve
I bought this dreambox off ebay and the seller set me up with it via msn messenger chat. i saved the conversation in case something like this happened. i have gone through it doing the following.
I have formatted the usb stick inserted into it. installed new gemini image to it. version Gemini_0440_DM7000.img.
I have downloaded the cccam 2.0.9 and cccam 2.0.9 config and installed them both.
I have forwarded ports 12000
16000
21
next i have installed my own services using dreamset216
all the info ip address and so on are set up on db and dhcp is off on router and db.
i have created a static ip address at no-ip.com
i dont know where to input this static ip address. when it came to this point in conversation he asked if he could log onto my db as its easier if he just does it and explains later on.
he did whatever he did and it all worked fine.
at the end of the conversation this was the explaination i received.
X says:
i basically updated the config file you downloaded from the gemini server with server details so that you can clear the channels
X says:
you need the flash fxp software to do this
X says:
or any other FTP software
ste says:
ok.
X says:
all i did was open the correct config file and cut an paste the server details
X says:
and told it which ports we were using.
X says:
any way got loads to do, catch you later
Any help would be very gratefully appreciated. thanks for reading. steve
