    Aug 2011
    Default Mercedes edc16 map pack with DTC structure
    I need help! One Mercedes Vito(edc16 0281 014 447) did not work correctly. Engine is in limp mode, no power. But no any fault codes. 2 week ago someone disable dpf from ecu(change software). Probably this is not good work. If someone could check file, is this correct dpf off or not? Or, if someone can give to me edc16 map pack with DTC structure to this car?!
    Thanks!
    Babos's Avatar
    Mar 2012
    not good solution!
  3. The Following 2 Users Say Thank You to Babos For This Useful Post:
    boomeer (3rd September, 2016), mihaiservice (3rd September, 2016)
    Aug 2011
    Is it because the engine is not working properly?
    Aug 2011
    Quote Originally Posted by Babos View Post
    not good solution!
    Can you help me with correct solution?
    Thanks!
    Jan1980's Avatar
    Nov 2014
    You have to post the original file..
    Aug 2011
    I do not have the original file.
