900rpm raised idle
test and report pleaseWinOLS (Seat Leon (idle 900rpm) - 386637) no chk.rar
I need to remap the engine ECU to increase the engine speed.
See attached dump from Bosch ME ECU.
Part Number 8P0907115B
IDENT: 1P0907115C 0020%Z82.0l R4/4V TFSI
IDENT: SEZ7Z0H3984405 RB8-65806.03.085BH16---13600147
Happy to pay for the service
When engine warm Idle is at 750RPM I need 850RPM or even 900RPM
I'm a guy trying to make a living
900rpm raised idle
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles) on allmost every petrol
djorgensen (7th September, 2016), moky (17th March, 2019)
ok will do now
didn't work, rpm down at 720, started at 1200 when cold start
this map is to 900rpm Leerlaufsolldrehzahl bei Kat.-Heizung (Desired idle speed for Cat.-Heating) 6x1map 1200.0 1200.0 1200.0 1200.0 840.0 760.0 all to 900rpm
this also to 900rpm Leerlaufsolldrehzahl: Erh?hung bei Hei?leerlauf (Desired idle speed: Increase At Hot idle) 560.0 650.0 700.0 750.0 750.0 750.0 840.0 840.0 all to 900rpm
Maybe it is possible with VCDS and a lot easyWinOLS (Seat Leon (900rpm v2) - 386637).rar
djorgensen (8th September, 2016), OsmarBR (18th March, 2019)
Couldn't find anything in Autologic, VCDS or VagCanPro to increase idle speed.
I will try that map now, thanks
that half worked. the start RPM junped straight to 900 but it still fell down to 720rpm when it got warm.
the original map and your v1 map started the engine at 1200rpm and then it fell down to 720
I got it working, thanks for your help anyway
How did you solve it?
Can you upload file with idle raised? Thank you
gttuning (10th September, 2016)
Hi,i have icresesed the idle speed on my car by vcds,but only 40 rpm.Would like to arive to 920 rpm at hot engine.Can someone help me please?
here is my ori file
here is ori file
