Hi mates,
EDC17CP14 VAG (golf 6) is it safe to make via OBD?
bootmode should work regardless of update and id with obd too
you havnt said what year car is could be gtp connections
tuning protection started 2009 and above so l wouldnt obd flash it , boot should worked fine are you using resistor or straight to boot cable ? l would use 1000ohm to boot cable and green to pin 87
l use grey boot wire to resistor to ecu on edc17c10 dosnt even need resistor
l use ktag 99.9% off the time tested mpps last year
my mpps pinout folder says dont use resistor
Col19 (24th December, 2019), twchnodictator (5th September, 2017)
sorry for my bad English
but if it is purple clone v18 I already made several without problems
[QUOTE = twchnodictator; 3099624] Hi mates,
EDC17CP14 VAG (golf 6) é seguro fazer via OBD? [/ QUOTE]
you only need to flash one with later s/w and you will have a very bad day
maajkii (7th September, 2017)
Audi A4 my2004 2.4V6 ME7.1 read/write via obd - OK
vectra 2.2 CDTI PSG16 read/write -OK
zafira Y20DTH PSG16 read/write - OK
