Page 36 of 50 FirstFirst ... 26313233343536373839404146 ... LastLast
Results 526 to 540 of 747
  1. #526
    Nov 2012
    Quote Originally Posted by tehnosoftex View Post
    Yesterday I try focus 1.6 edc16c34.5 euro5 and failed. It reads ok but when try to write, it goes to 100% and after that it writes transfer aborted and car was killed. I resuscitate it with vcm2.
    This car only bdm. Rsa protection . So no chance by obd right now. At least not with any tipe clones.
  2. #527
    twchnodictator's Avatar
    Aug 2015
    European Union
    Hi mates,
    EDC17CP14 VAG (golf 6) is it safe to make via OBD?
  3. #528
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Quote Originally Posted by twchnodictator View Post
    Hi mates,
    i think TPROT is from sw1037515000 up so below that and no updates at dealer should be ok
  4. #529
    Aug 2015
    European Union
    Quote Originally Posted by smirnoff_rules View Post
    Tried to read via OBD. Can't read.
    Via boot tricore also no luck. Galletto also failed. Can't understand what is the problem. Car was in the dealership not so long ago with updates caused by dieselgate scandal. Could it be the reason?
  5. #530
    Mar 2008
    birmingham
    bootmode should work regardless of update and id with obd too
    you havnt said what year car is could be gtp connections
  6. #531
    Aug 2015
    European Union
    2009 production year
  7. #532
    Mar 2008
    birmingham
    tuning protection started 2009 and above so l wouldnt obd flash it , boot should worked fine are you using resistor or straight to boot cable ? l would use 1000ohm to boot cable and green to pin 87
  8. #533
    Aug 2015
    European Union
    I used 1000 ohm only only boot pin, exactly how it was in galletto tutorial
  9. #534
    Mar 2008
    birmingham
    l use grey boot wire to resistor to ecu on edc17c10 dosnt even need resistor
    l use ktag 99.9% off the time tested mpps last year
    my mpps pinout folder says dont use resistor
  10. The Following 2 Users Say Thank You to smirnoff_rules For This Useful Post:
    Col19 (24th December, 2019), twchnodictator (5th September, 2017)
  11. #535
    tinaca's Avatar
    Jul 2009
    Portugal
    sorry for my bad English
    but if it is purple clone v18 I already made several without problems
  12. #536
    tinaca's Avatar
    Jul 2009
    Portugal
    [QUOTE = twchnodictator; 3099624] Hi mates,
    EDC17CP14 VAG (golf 6) é seguro fazer via OBD? [/ QUOTE]
  13. #537
    Mar 2008
    birmingham
    you only need to flash one with later s/w and you will have a very bad day
  14. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    maajkii (7th September, 2017)
  15. #538
    Apr 2012
    London
    Audi A4 my2004 2.4V6 ME7.1 read/write via obd - OK
  16. #539
    Apr 2012
    London
    vectra 2.2 CDTI PSG16 read/write -OK
  17. #540
    Apr 2012
    London
    zafira Y20DTH PSG16 read/write - OK
