Page 38 of 50 FirstFirst ... 28333435363738394041424348 ... LastLast
Results 556 to 570 of 747
  1. #556
    Apr 2016
    hello.
    EDC16C2 W203 mercedes mpps v18 EU CLONE not work ...
    regards
  2. The Following 2 Users Say Thank You to bocaje For This Useful Post:
    Col19 (24th December, 2019), poxxxy (18th February, 2018)
  3. #557
    Mar 2016
    I try but chinrese
  4. #558
    Mar 2016
    not worl is fake
  5. #559
    Jan 2010
    Trstenik - Thun
    For what purpose exactly used resistors R14 and R114 ?I have 102 value and my mpps v18 working well ,r/w everything without problem but i saw that some variants use value 511 .
  6. #560
    May 2014
    LIthuania
    Quote Originally Posted by zyjekrc51 View Post
    vectra 2.2 CDTI PSG16 read/write -OK
    Hi did you read write by obd ? Cause mine only read by obd but no write and i dont know why
    Išsiųsta naudojantis HUAWEI TIT-L01 Tapatalk 4 Lt
  7. #561
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Quote Originally Posted by smirnoff_rules View Post
    did Volkswagen Tiguan 3.0 petrol me7.1.1 and wasnt any problem , first batch mpps18 , its been a great tool
    combo 1.3cdt mj60 something worked fine , sid802a peugeot read and right with can
    I killed me7.1.1 a8 d3 4,2l with v18 It reads ok but can not bypass security and kill ecu in writing.
  8. The Following User Says Thank You to Faraday For This Useful Post:
    Col19 (19th January, 2020)
  9. #562
    DK Veteran stevan's Avatar
    Dec 2008
    Bosnia
    Quote Originally Posted by PaoloDigital View Post
    I try excange u12 with si9241A , not work , you are 2 version pcb , and 1 problem stability tension on k-line and can line , mod your mpps with this link:
    https://www.linkedin.com/pulse/mpps-...work-kent-elsa
    http://ecuprogram.webstarts.com/blog...one-pcb-rework
    Are 2 pcb 20160905 and my 20170211 , different
    You must solder K line driver in empty U8 place not in U12 where is Lm2903
    Poslano sa mog ZTE Blade V6 koristeći Tapatalk
  10. The Following 2 Users Say Thank You to stevan For This Useful Post:
    Col19 (24th December, 2019), PaoloDigital (23rd December, 2017)
  11. #563
    Dec 2008
    Bosnia
    Note that U8 pinout is not for Si9241,compare with L9637d and will see difference,RX,TX,VCC...
  12. The Following 2 Users Say Thank You to stevan For This Useful Post:
  13. #564
    Sep 2009
    buy original if u work
  14. #565
    Mar 2016
    I solded in U8 , i check pin pcb with pinout si9214a datasheet , and removed L.03.. U12 , but not work, i tested also with 2, i resolded Lm2903 and mod ocb ...2017.. as 2016 .. and work read and writw 59f under 100 , but nor 59f over 100. I wont now replace L2903.with L9637d thank
    Original schematic is not as clone. different
    Quote Originally Posted by stevan View Post
  15. #566
    Mar 2016
    You are differente from lm2903 and L9637d ? Lm9637d go to U8 if replace lm2903? thank
  16. #567
    DK Veteran maybach_'s Avatar
    May 2010
    EU
    Hi mates
    I have a V18 Clone and want to read my Berlingo ECU with EDC17C10 but can't see whare are the meny for EDC17 ecu
    can someone help add video or foto how to do
    Thanks in advance
    Be allways Thankfull!
  17. #568
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Hy guys, just a stupid questions from me, I am new to using mpps v18 ,I have buyed one to play with, how can I check TP level on edc 17 vag???
    Trimis de pe al meu SM-G930F folosind Tapatalk
  18. The Following User Says Thank You to DR Race For This Useful Post:
    sdtsedat (12th February, 2018)
  19. #569
    Jan 2014
    Ro
    peugeot 307 1.6 edc16c34 read write obd..ok
  20. The Following 2 Users Say Thank You to tarabostesul For This Useful Post:
    Col19 (24th December, 2019), dritan (7th February, 2018)
  21. #570
    Apr 2012
    London
    HI!
    YES READ/WRITE by OBD
    some other PSG16 I had to read and write directly via connector on PSG16 because by OBD no connection established.
