Page 44 of 50 FirstFirst ... 343940414243444546474849 ... LastLast
Results 646 to 660 of 747
  1. #646
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by figani View Post
    I used V18 for a Magneti Marelli Fiat 6F3... on bench... multiboot option...
    flash... successful...
    mpc... successful...
    eeprom... failed...
    open it and read it by Ktag... and compare it...
    v18 corrupt data from eeprom...
    read 5 x eeprom by V18... everytime another result...
    you use clone?
    if yes is China or EU clone?
  2. #647
    carmageddon's Avatar
    Apr 2010
    Italy
    eeprom... failed...
    i did mj6 and mj8 via obd with mpps multiboot, never on the bench...no problem
  3. #648
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Yes, 100% clone... Bought it before years as reworked...
    I had only ecu, not car... I read flash/mpc also several times... Each time same... Only Eeprom was not same... Why... Really don't know...
  4. #649
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    well i read on bench over 10 times (and write a couple) the eeprom of one marrelli 6f3..... always with success...
    and i compare the files..... you have right..... always a bit different like count something.. (44,45,46 etc) but only that different....
    eepromtest.rar
  5. #650
    figani's Avatar
    Feb 2018
    It's maybe a counter...
    As I wrote, after that open it and read by Ktag, several times... Every time the same...
    At the end... Solder down Eeprom and read it...
    Compare with Ktag, and same...
    Compare it with V18, and not same...
  6. #651
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Anyway, i have read-write many times eeproms of that kind of ecus, never had any trouble.....
    i have a fiat right now, i read eeprom via OBD a couple of times to see if there any difference....
    what difference you got comparing mmps and ktag eeproms?
    is like the eeproms that i have upload?
  7. #652
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Update for mpps v18 clone But NOT China..... eu clone.....
    yesterday i brick an ecu....... read in boot mode flash,micro, eeprom.... all ok
    i start one more reading of the flash for compare..... at the half of reading....... no connection with ecu?
    the ecu now is dead..... marelli 6o3...... no connection with op-com no hearing of the pump.... a big F on dash...
    that is Very sad for me..... i had a big respect for that tool.....
    and i dont know if is possible to recover the ecu.....
    i Guess not....
  8. #653
    Member rh03's Avatar
    Jul 2017
    France
    Quote Originally Posted by Panathaole View Post
    i Guess not....
    Marelli ecu are capricious, the best way is to do full backup on bdm with ktag, then flash obd with kess or mpps
  9. The Following User Says Thank You to rh03 For This Useful Post:
    Panathaole (20th December, 2018)
  10. #654
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Thank you
    I give a try....
    I have take after brick a ktag backup...
    And I have the backup of the mpps....
    Thanks.......
  11. #655
    Jul 2017
    France
    Thank you
    I give a try....
    Thanks.......
    So I think you can recovery your ecu,
    your ktag flash should be FFFFFFF.... , and your flash MPPS is ok, you should find the corrupted zone on ktag flash copy your mpps flash in this location, calc checksums and write the fixed flash with ktag.
  12. #656
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    i have exactly the same files (ktag & mpps) no ffffffff
    the only difference are in micro... ktag gives me 513 kb and mpps 512, at the end of the file i have a few lines with ffffffff
    no other different..
    the mpps cut of the power of the pump and i don't know what else.... is like set the ecu to safe mode.....
    and at the end of reading , just recover the ecu....
    now is like i have the ecu in safe mode .......without any driver load....
  13. #657
    Mar 2016
    Hello Friand, Merry Cristmas for all.
    I bricket blockjed my v18 ,whith used software v21 , not reconize to pc . lock!! , you have file firmware to reflash Cf8051 ... , i not finded cf8051 flashed recange, thanks for any response.
  14. #658
    Dec 2018
    Hey guys, I have MPPS V18 that I am suspecting has an internal short. Those who have one of these would you mind hooking up power to it and checking voltage on the Kline? I am getting 12 volts which I suspect is incorrect.
  15. #659
    Mar 2016
    Quote Originally Posted by bignslow View Post
    You have zener diode on 12v , i removed D4 and D6
  16. #660
    Oct 2014
    Latvia
    Hello, i have issues with v18 i cant conect to kline. can works fine. half year it worked perfect .can somoene help me? dont want to buy new tool.
