i can help u, post ori file too pls!
Hi everyone !
Please help, I need checksum correction on Ford Mondeo 2006
engine 2.0 85kw tdci
Ecu DELPHI 6S71-12A650-BG mpc555
Full bdm MPC555 damp read attached
Mondeo 2006 2.0tdci all_MPC555_.rar
CRC OK by Genuine WINOLS.
CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
DTC OFF, LIMP HOME MODE OFF!!!
ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
HOT/COLD START
CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
TRANSLATE DAMOS ENG
COUNTER FIX - VAG EDC16, EDC17
ORYGINAL FILES DATA BASE
START/STOP ON/OFF
porter77 (12th September, 2016)
Have the same ECU but with DPF off. Can someone please correct checksum?
Engine will not start. Immobilizer flashes
Hello mates.
Need calculate CS for similar ECU. Modified MPC dump is attachment.
Thanks in advance.
Mondeo MPC_(6S71-BG) need CS.mpc.zip
Professional EGR, DPF, CAT, VSA, NOx, ADBlue, DTC solutions here...
File for you CRC OK
HOT/COLD START
TRANSLATE DAMOS ENG
START/STOP ON/OFF
All the solutions above are just DTC off....
Could you please correct the checksum of this file, too?
Thanks in advance
