Results 1 to 8 of 8
    Oct 2011
    Planet Earth
    Default Ford Mondeo 2006 Delphi 6S71-12A650-BG
    Hi everyone !
    Please help, I need checksum correction on Ford Mondeo 2006
    engine 2.0 85kw tdci
    Ecu DELPHI 6S71-12A650-BG mpc555
    Full bdm MPC555 damp read attached
    Mondeo 2006 2.0tdci all_MPC555_.rar
    Jun 2016
    i can help u, post ori file too pls!
    LaraVAG's Avatar
    Jun 2011
    Poland
    CRC OK by Genuine WINOLS.
    CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
    EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
    DTC OFF, LIMP HOME MODE OFF!!!
    ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
    HOT/COLD START
    CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
    TRANSLATE DAMOS ENG
    COUNTER FIX - VAG EDC16, EDC17
    ORYGINAL FILES DATA BASE
    START/STOP ON/OFF
  4. The Following User Says Thank You to LaraVAG For This Useful Post:
    porter77 (12th September, 2016)
    Dec 2013
    GB
    Default please correct checksum
    Have the same ECU but with DPF off. Can someone please correct checksum?
    Engine will not start. Immobilizer flashes
  6. #5
    Oct 2010
    Default need checksumm
    Hello mates.
    Need calculate CS for similar ECU. Modified MPC dump is attachment.
    Thanks in advance.
    Mondeo MPC_(6S71-BG) need CS.mpc.zip
    Professional EGR, DPF, CAT, VSA, NOx, ADBlue, DTC solutions here...
  7. #6
    LaraVAG's Avatar
    Jun 2011
    Poland
    File for you CRC OK
    HOT/COLD START
    TRANSLATE DAMOS ENG
    START/STOP ON/OFF
  8. #7
    Apr 2011
    All the solutions above are just DTC off....
  9. #8
    Sep 2013
    Could you please correct the checksum of this file, too?
    Thanks in advance
