Page 10 of 12 FirstFirst ... 56789101112 LastLast
Results 136 to 150 of 180
  1. #136
    rafisoltys's Avatar
    Apr 2017
    Quote Originally Posted by szczapek1996 View Post
    Hi guys I have BMW 525D 2007 177hp i have kess v2 i read map I use one online service for remap , After upload to car , the car start but straigh away go max rpm
    I upload orginal and remap from the service can some check it for me whats wrong with it beacuse online service said everything is ok . after upload orginal the car start normal
    It is classic based on Duration Map decalibration
    Do not waste time for checking more.
  2. #137
    Dec 2014
    chiapas
    Default help EGR off ecu denso TD 2500 nissan NP300
    Hi guys,
    i need help, for EGR off ecu denso N8 nissan TD 2500 model 2015,
    HW: E30RU4D_T2F0D22014
    SW: 5800780
    SW_UP: VM11A
    ktag reader.
    tankyous
  3. #138
    Jun 2018
    Bulgariq
    Quote Originally Posted by guzmancillo View Post
    Hi guys,
    SW: 5800780
    SW_UP: VM11A
    ktag reader.
    tankyous
    Thanks and Reputation
    Pass-PM
    test and report
  4. The Following 2 Users Say Thank You to naskochipa For This Useful Post:
    nabilahmed (10th March, 2021), nbg0x1 (23rd September, 2020)
  5. #139
    DK Veteran WOODWARD395's Avatar
    Manchester UK
    Hi when an EGR delete is done and the EGR is left on site, has the vacuum pipe got to be clamped blocked off or do mappers stop the vacuum to EGR.
    Education is not the learning of facts, But the training of the mind to think
    So hit the thanks button if I have enlightened you.
  6. #140
    Feb 2020
    England
    Quote Originally Posted by WOODWARD395 View Post
    Vacuum solenoid/control valve whatever you want to call it shouldnt let EGR valve open if it has been deleted from ECU.
    Not 100% sure though.
  7. #141
    Jul 2019
    Denmark
    hello evrybody... im flashing with kess and ktag on a jaguar xf 3.0 6 cyllinder 240 hp the sw is 503430
    i have micro(maps)
    extflash
    eprom
    but no matter how i do the flash
    ither the car wont start or the car has a fault on engien when applying gas
    how would you flash it
    im thinking about with kess 2.53 and flash partial????
    im forced to flash car on bench
  8. #142
    Default Alfa Romeo 159 Jtdm 1,9 16v 150hp stage 1
    Hello Dear fellows please help me with My car Alfa Romeo 159 1.9 JTDm 2006 16v 150hp. Pls disable SWIRL, EGR and DPF (my dpf is phisically out with down pipe) add please add more HP with stage one,km 230,000 and ecu file is read with galetto China clone.
    Fiat Hardware Number :55205068
    Bosch Hardware Number: 0281012144
    Bosch Software Number: 1037377871
    Bosch Software ID: 3442
    ALFA 159 1.9 MJET 16V
    Bosch EDC16C39 CF4/EOBD Diesel Injection (1.9, 2.4)
    ECU ISO code: FD 86 3D 04 19
    FIAT drawing number: 55205068
    Hardware number: 0281012144
    Hardware version: 00
    Software number: 1037377871
    Software version: 3442
    Homologation number: 93942
    ECU programming date: 09/03/2005
  9. #143
    Sep 2020
    hello someone have a link for hardcut limiter for diesel program to download please ?
  10. #144
    Junior Member nbg0x1's Avatar
    Jul 2020
    Kurgan
    [QUOTE = maajkii; 3034373] [ATTACH] 451272 [/ ATTACH]
    Попробуйте это и сообщите.
    Пароль в личку [/ QUOTE]
    can I use a password
  11. #145
    NASTASE's Avatar
    ROMANIA
    Why so many passworded files?Please read what Johnner user wrote "Hopefully with the idea that the more experienced guys would help out/teach people new to it ,out...and that the inexperienced guys would report back on their results...which I think is only fair ?"Want to help and teach ? no password ,want to protect your work?need money?go to other topic.Ask for tuned file?here is not the right topic.Why is so hard to fallow few simple rules?
    Real engines don't need forced induction
    Who needs a turbo when you have a stupidly quick naturally aspirated engine?
  12. The Following 2 Users Say Thank You to NASTASE For This Useful Post:
    AbdelD (6th July, 2022), AlexVW (14th October, 2020)
  13. #146
    Oct 2020
    Hi can someone who works with tuning VW DSG's tell me what programs they use or any procedures to help me get started? I realize this is an engine tuning discussion but I think the same principles apply in this case.
  14. #147
    Oct 2020
    Hello, I don't know if i'm in the right place to ask this but maybe someone can direct me.
    I want to start learning about how to read ecu's, what software and hardware i need to extract the map from the ecu en how to change the map.
    Are there any tutorials about ecu-tuning?
  15. #148
    Mar 2015
    Hey. Anyone from experienced colleagues here is able to help with the MED 9.1 RS4 B7 4.2 driver
    I need to do Flat shift + Boot routine + Pops & Bang
  16. #149
    Dec 2018
    I WANT STAGE 1 OR 2 IF YOU CAN
    PEUGEO 0281 010166+virgn+1999+107ch.rar
    THNX
  17. #150
    Jan 2021
    Hello, can someone explain to me how the pedal map (x axis - % accelerator pedal, y axis - rpm) coefficient works in Siemens SID? For example, if the coefficient is 0.5, what does it refer to? if 1, for what? Up to torque, I suspect, but I don't know exactly how.
    Second, why is there a map in Siemens SID that converts IQ to Nm and another that converts Nm to IQ?
