can that method of closing the egr be applied to ford edc16c7 as well?
http://www.digital-kaos.co.uk/forums...-map-addresses
Denso, Transtron, Hitachi & aftermarket Standalone ECUS
What is the best software to edit dump from Sirius32 ?
I am new to ECU editing and need guidance
I have "TunerPro" but do not know how to use it...
Which one is best and what's the difference? .. "WinOLS" "TunerPro" "RomRaider" "ECM Titanium"
thank you![]()
Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
shooting (10th November, 2016)
for me as a beginner ECM Titanium was the first, where I started to understand, everything is intuitive, but it is only for chip tuning, EGR, DPF, swirls, this is not a good solution, here need winols, experience and have head on your shoulders, from side it seems simple, but it is not
tell me thanksI will be very happy
shooting (9th November, 2016)
can some one share some info about bmw dpf off for edc16c31/35?
From what i've experienced so far there are multiple "things" to "zero" out for a good solution. And i woould like start here a list and i would like that you guys join and correct me if i'm wrong and aprove if i am right.
1 Mask for blocking and activating regeneration measures (1x1) also known as "dpf switch"
2 Static Particle Emission Calculation map (8x8)
3 Stationary Particle Mass Flow map (8x8)
4 Upper and Lower Hysteresis for Injected Quantity in Regenaration Mode (both are 6x1)
5 Soot Mass in Particle filter (8x1)
6 DPF flow related DTC's :
4CF3 Exhaust Backpressure Sensor
4166 Particulate Filter system
4165 and 4166 both for DPF flow resesitence high and low
4628 DPF System
4665 DPF Bank 1
4666 DPF Bank 1
4667 DPF Bank 1
480A DPF -Bank 1
481A DPF -Bank 1
4618 DPF -Plausibility -Pressure Reference
and i know there are more switches to turn off and maps to zero out (like post injection maps) for a proper dpf off solution, but i don't know what has to be set to 0 and i will like to learn about this.
CarCity (2nd December, 2016)
yes ecm titanium is first software for newbie, like me i think. I can do some things on winols but still learning.
Hi guys!
Wanted to ask - having car VW Passat B6, 2.0tdi - if i will delete TVA does DPF regeneration will work normally?
Need to delete TVA, but don't want to touch dpf. Thanks in advance!
bobolin4o He is right. But 5th gear and full press brake too.
You are right bobolin4o! Then is problem.
