Page 8 of 12 FirstFirst ... 3456789101112 LastLast
Results 106 to 120 of 180
  1. #106
    Mar 2019
    Czech rep.
    hello, i would like to ask You what kind of data is stored in eeprom and in flash memory.
  2. #107
    Dec 2018
    Hello I need help please If possible file tuning stage 1
    pegout 406 2.0 hdi 110ch edc15c2
  3. #108
    Dec 2018
    Default Hellp
  4. #109
    Dec 2015
    Italy
    if you post the file ...
  5. #110
    Dec 2018
    Did not matter m'y immo off
  6. #111
    Dec 2018
    Pegout 406 file tuning stage 1
    2.0 110 HDi EDC15C2 2000
    Kess v2
  7. #112
    Oct 2017
    Hello everyone, I need advise on these two files.
    Put into consideration the following.
    VW Golf 5 GTI
    2.0TFSI (AXX BWA block)
    DSG (02E)
    MED9.1
    2005
    K04 (+3mm)
    Intake manifold flap delete
    Turbo muffler delete
    3" intake
    3" half exhaust (200 cell cat)
    Charcoal canister delete
    PCV delete (oil catch can)
    DV relocation kit
    Polished cylinder head
    Forged block
    WMI (De-H2O)
    Thank you sooo much
    Robin BVW Golf 5 GTI_Maps.zip
    Kess V2 . K-Tag
    MiniPro . UPA . VVDI2
  8. The Following User Says Thank You to robinbga For This Useful Post:
    Milenium (2nd June, 2019)
  9. #113
    May 2019
    I'm looking map to my car Lancia Phedra 2.2 128km 94kW with EGR off, FAP off, stage 1 or stage 2.
    I'll send my orginal maps file if someone wanted help me.
    I have galletto v54.
  10. #114
    Dec 2015
    Italy
    post the file
  11. #115
    Oct 2017
    Quote Originally Posted by robinbga View Post
    VW Golf 5 GTI
    DSG (02E)
    MED9.1
    2005
    K04 (+3mm)
    3" intake
    DV relocation kit
    Forged block
    WMI (De-H2O)
    Thank you sooo much
    Kess V2 . K-Tag
    So no one is willing advise the best file to use?
    Kess V2 . K-Tag
  12. #116
    Jun 2019
    Hi guys! I have a Fiat grande punto 1.3 90 multijet, they removed the diesel particulate filter and filled it with firmware without DPF, but now it starts to raise engine speed to the maximum for the hot one before you start driving, has anyone encountered this?
    51806505 DPF
  13. #117
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by mrwa View Post
    51806505 DPF
    wrong tuning...
    you gonna break your engine...
  14. The Following User Says Thank You to Panathaole For This Useful Post:
    mrwa (18th June, 2019)
  15. #118
    Jun 2019
    Quote Originally Posted by Panathaole View Post
    wrong tuning...
    Hello Panathaole! Thanks for the answer, I have been driving for almost 4 months now. I noticed that it appears only when the car is warm to operating temperature, the arrow in the middle. If the temperature drops slightly, the engine speed increase will not occur at startup.
    In order for the engine speed in this situation to return to normal, it is enough to switch on any gear and drive a couple of meters.
    What should I do? Download clean firmware to my engine control unit?
  16. The Following User Says Thank You to mrwa For This Useful Post:
    Redzonepower (18th June, 2019)
  17. #119
    Oct 2018
    no problem, just work on firmware in warmup idle speed,
  18. #120
    Jun 2019
    no, RPM going to maximum not +100 or +200 and ONLY on hot engine
