Hello I need help please If possible file tuning stage 1
pegout 406 2.0 hdi 110ch edc15c2
if you post the file ...
Did not matter m'y immo off
Pegout 406 file tuning stage 1
2.0 110 HDi EDC15C2 2000
Kess v2
Hello everyone, I need advise on these two files.
Put into consideration the following.
VW Golf 5 GTI
2.0TFSI (AXX BWA block)
DSG (02E)
MED9.1
2005
K04 (+3mm)
Intake manifold flap delete
Turbo muffler delete
3" intake
3" half exhaust (200 cell cat)
Charcoal canister delete
PCV delete (oil catch can)
DV relocation kit
Polished cylinder head
Forged block
WMI (De-H2O)
Thank you sooo much
Robin BVW Golf 5 GTI_Maps.zip
Kess V2 . K-Tag
MiniPro . UPA . VVDI2
Milenium (2nd June, 2019)
Hello,
I'm looking map to my car Lancia Phedra 2.2 128km 94kW with EGR off, FAP off, stage 1 or stage 2.
I'll send my orginal maps file if someone wanted help me.
I have galletto v54.
post the file
Hi guys! I have a Fiat grande punto 1.3 90 multijet, they removed the diesel particulate filter and filled it with firmware without DPF, but now it starts to raise engine speed to the maximum for the hot one before you start driving, has anyone encountered this?
51806505 DPF
mrwa (18th June, 2019)
Hello Panathaole! Thanks for the answer, I have been driving for almost 4 months now. I noticed that it appears only when the car is warm to operating temperature, the arrow in the middle. If the temperature drops slightly, the engine speed increase will not occur at startup.
In order for the engine speed in this situation to return to normal, it is enough to switch on any gear and drive a couple of meters.
What should I do? Download clean firmware to my engine control unit?
Redzonepower (18th June, 2019)
no problem, just work on firmware in warmup idle speed,
no, RPM going to maximum not +100 or +200 and ONLY on hot engine
