I've got a 05 saab with missing CIM. What are the options in this case?
I have tech2 and tmpro2. Would it be posible to get used CIM make a key for it and add it to the car by tech 2
Do you have any `old` keys for the car?
if so reset used cim,only 2 eeprom files, with or without esp, most have esp
then add cim keeping existing keys with tech 2
GameTheoryOptimal (13th September, 2016), rrador (14th September, 2016)
Reset of the used cim is done by reprogramming the 93lc66 chip, very easy on those mate.
but that wont help you if you have no working keys, they are stored in cim and ecu, when cim is reset key data is copied from ecu to new cim so you
can reuse existing keys,you need at least 1 working key to do it that way.
in your case you have to make a key from the used cim with tnpro,then `add` the cim with tech 2 once you have a working key
worth checking the antenna on the old key,they fail quite often and if you change that and the key is identified the process is slightly easier
if you cant find the reset cim eeprom file in the search, i can pm it if needed mate.
darknezz19 (29th May, 2020), GameTheoryOptimal (16th September, 2016), rrador (15th September, 2016)
Thanks for the help got it running today, original key was toast, shell was actually empty no board inside.
Just made a key for used CIM and added it to the car with tech2, easier than I thought
foxtec800 (16th September, 2016)
How about CIM cloning ? Is it possible to read CIM's eeprom and write it to new cim ?
Virginize the cim use the tech2 with Saab card and a daily subscription. Get a new key and go threw the menu.
Oktawian (29th May, 2020)
Any idea where to buy this dayli subscription ?
Found this :
https://www.acdelcotds.com/subscriptions
Need to check if its for euro saab as well.
So I've left with my old CIM, person who tryed read 93LC66a corrupted the eeprom in it.
New cim with keys and guy with tech2 done the trick.
now when i've got hitag2 programmer and xprog i can try to make it working again.
I do not have tech2. I've already put virgin dump to the old CIM.
Simplest thing is to programm it by tech2 to saab, but don't have tech2.
Is it possible to read working CIM from saab and write its eeprom the old cim ?
My plan is to make 2 keys for old cim and sell it to get some cash back for used cim, that i've bought for the saab due to guy messed up the eeprom in original cim.
